Does it "NEED" to excel?
I can't say if it needs to or not. I can do it, and have done so many times.
You wrote:
"After which the blade is then taken to a full 90 flex. You really don't want it to take a set/bend.
....A properly done blade, as well, would have RETURNED nearly straight after going 90 degrees with no cracking in the hardened portion.
If any part of the test fails, the knife fails."
I doubt that the 4" long blade with 1/4' in the spine will do that. Let's assume that "near straight" means 10 degree residual deformation angle. I doubt that this geometry blade can be even bent to 90 degree if it has any considerable hardness. The steel has it's limits. Sorry.
