- Aug 24, 1999
Man, the two things I look for in the ideal shower...
I want it hot enough to darn near scald me, and enough pressure to cut D2!!
If I can get one or the other, I'm okay, but a shower that feels like heated needles on me...man, that's good!!!
If I can't get at least one or the other (I prefer pressure to heat, if it comes to a choice), I advise keeping at least a seventeen-foot "safety radius" around me. Within that range, I cannot assure your safety, as I am 'slightly grouchy.'
Cold is good for toning the skin at the end of a good, hot shower, though!
Slightly off-topic...I used to go to a gym that offered access to a sauna, steamroom, hot-tub, and 'cold dip' pool. It was very Spartan...the sauna was usually about 240 degrees (make sure to take a wet towel to sit on!!), the hot tub was usually about 114 degrees, and the cold pool (actually a hole in the ground about four foot diameter, with steps down into it) was usually about 45 degrees. When you're really feeling your oats, try making the shift, sometime. A 200+ degree temperature differential will you make you feel...unique. I know that those nutty Fins do it all the time, but the first time you try it, let me guarantee you that you'll be trying to coax your gonads out of your armpits, where they're whimpering and hiding, trying to rub against your lymph nodes for warmth!!
