I could see it possibly being a problem with a liner lock knife, but even then the knife would probably have to already have a late lockup.
Please explain how lockup % of a liner lock affects side to side blade play.
This Spyderco Para 2 in Cammo and S30V DLC coated steel has zero play an pivots so fast and light I can not imagine having a knife that does any better.
This Benchmade 710, which is a more expensive version of this model being a limited edition in M390 steel ( I simply love the handle shape and this steel alloy) . . . well . . . the pivot sucks so bad. It has play, when the knife is room temp or cooler and it swings free, when I carry the knife in my pocket it warms up to body temp and even with a trace of play it doesn't pivot nearly as well as it should . . . if I put it in the refrigerator . . . the materials go right back to pivoting freely.
I've had a cheap knife with blade play and late lockup, and if you moved the blade the lock bar could travel all the way across.
This is just the worst case scenario with a piece of junk though.
Yep jammed open, but it had already lost two body screws so I threw it away instead of trying to get the lock bar uniammed.And it closed and cut you? Slipped completely of the tang and jammed the knife open? What's the worst case scenario?
If you were doing something that put stress on the lock, like pulling it out of a stiff medium that the blade is wedged in (hard food, rubber, cardboard, wood, etc) or turning with the knife in hand and accidentally hitting a solid object, then it could possibly close inadvertently. It seems like it only takes a small change in the angles of the engaging surfaces to make most locks fail, and this doesn't appear to be an uncommon event among people who get serious cuts.And it closed and cut you? Slipped completely of the tang and jammed the knife open? What's the worst case scenario?
Ok. So the liner lock had nothing to do with the side to side play, and wasn't at fault. You were using a (broken) knife with missing parts.
Thank you for the explanation.
Right, but you asked what the consequences we're, and it seemed like you're inferring there aren't any if it slips towards the show side. Which is usually true, but a bit disengenuous because in that scenario it could also easily slip the other way.Yes, this I know. But this wasn't about lock slippage towards the lock side.
For a liner lock, with late lockup (touching the opposite liner), to slip all the way to the lock side and disengage from blade play?
I suppose it could happen. Though I wouldn't say easily.
That would have to have a whole lot of play. Or a very loose wide bodied knife with a thin tang and thin lock tab.
Though in this specific scenario it did slip off on the opposite side.
I m the opposite. I d rather have a folder with no side to side play that doesn t fall shut freely. If I get a knife with a small amount of side to side play that has the blade fall freely on closing, I ll tighten the pivot to allow a smooth opening and closing with finger pressure, but has no play whatsoever. I personally don t see the benefit of a free falling blade on closure. Just as with a slight bit of play, there is no functional problem with a non free falling blade. More of an aesthetic preference. Which I don t share.Many of my knives have a tiny bit of lateral play. I don't have an issue if you have to really force it to move, and the lock itself doesn't rock. It's more of a nitpicky issue if it's just a smidge of play, but if the blade rattles it can induce failure. I'd rather have free dropping with a hint of play than stiff with no play.
Well, I have heard that liner locks/frame locks depend on a 7-10 degree engagement angle. If it was right at the edge of that anyway, and you deflected a loose blade... who knows. I don't think it's likely to occur but then again I don't tend to put any force on frame/liner locks. Also, I'm not saying a knife with the liner already touching the other side, but a normal liner lock with normal engagement. I'm assuming it slips open rather than closed because that's usually what I've seen failing liner locks do.
It may only slip closed if you forced the blade sideways while you had a load applied against the lock. However, I think that might be easily possible if you pull a stuck knife out of something very stiff.
