- Jun 29, 1999
I enjoy a natural patina. Some of my best memories are painted on the blades of my Marbles Campcraft and Cold Steel Master Hunter.
I do. But I also reapply a thin layer of cooking oil after it's dried off, per the instructions for the skillet. That's been working well for me so far. They do recommend washing (not just 'rinsing') by hand as any other dishes would be done, BTW.
you're not using soap when you wash it, are you?
If you have a proper seasoned pan you can wash with warm water and soap as long as you aren't using a scouring pad. I've never understood why this is so taboo.I do. But I also reapply a thin layer of cooking oil after it's dried off, per the instructions for the skillet. That's been working well for me so far. They do recommend washing (not just 'rinsing') by hand as any other dishes would be done, BTW.
Those biscuits look great.I don't have cast iron... (glass stove top) but I have two Lodge carbon steel pans that I use. They season the same way cast iron does. About 80% of the time, I can simply wipe them out with a paper towel after use... occasionally I will have to fill them part way up and let them soak with water. Then I use a bristle brush to remove any stuck food, rinse, then dry on a low burner heat. Once dry, I wipe with cooking oil, and let that heat up long enough to harden it. The smaller pan is for eggs, grilled cheese sandwiches, etc.... the larger pan is mostly for biscuits, or other larger dish items...
The pans are about as non-stick as any pans I've used.
Although cold blue liquid is highly toxic, I don’t believe there’s any chance of a cold blued knife causing poisoning.How about cold bluing though ? I’ve always avoided using blued knives on food after reading it was toxic.. can’t remember where I read that. Anyone have any feedback on that matter ?
Looking good. What are the two knives on the right?View attachment 2682052
Can’t have a thread about patina without pics - like non alcoholic whiskey
No vinegar was used for these.. just kitchen and chore duty.
The two on the right David Beck: bigger one is a “Ledge Rock” 2024 run for BCUSA , and the smaller one is a Saranac 5 - 1/8 stockLooking good. What are the two knives on the right?
I like those BecksThe two on the right David Beck: bigger one is a “Ledge Rock” 2024 run for BCUSA , and the smaller one is a Saranac 5 - 1/8 stockDifferentially heat treated 01 steel on both.
