- Jun 11, 2006
I thought i would post some info for the new blade smith that i have found. first one of the most commen question is, how can i tell if my blade is hard. well if you heat treated it your self there are so things that you need to be awar of. first if you are using a torch to heat the blade and not wraping the blade in stainless steel foil to protect if from the air the blade will be hard but will not seam hard. what this means is you will test it with a file and it will kinda bite in and leave surfaces scraches. but dont let this fool you, what happend is while heating the blade you burned the carbon out of the top layer of steel which is a fue thousandths. if you remove this layer you will see that its super hard and a file wont even tuch it. In my experance i like this because it makes for an easyer miror finish because the top layer that has the scratches is easyer to remove. on my blades I use O-1 and after heat treating my used file will seam to cut like it was never hard. but a quick pass of the belt grinder at 120 grit remmoves this layer. i go back and test with a file and nothing not even a scratch with a new file. I just thought i would let the new people know about this so thay dont keep trying to harden there blade because there file bites in right after heat treat. just thought i would pass the tip.
