David Martin
Moderator
- Apr 7, 2008
I think if you are having "file marks" on the edge you are either A) Using it wrong B)Using the wrong type of fileI suppose if you use a fine file lightly you may not remove more material than a stone. However I don't like the file serrations on a working edge because they tend to grab more sap and wood and eventually compromise the bite to a degree--so I would stone after filing which means I would end up removing more material. After initial filing of the geometry I seldom use a file again--I would only use it if I needed to reset the geometry. A fine file can work well for a scythe to *grab" types of vegetation which might tend to slide off a polished edge.
In my opinion a honed edge vs. a filed edge is a bit less apt to chip in harder wood because it is more polished and has less friction. It is less apt to build with sap because there are no fine serrations.
My comments on filing are not intended to imply that a filed edge is a structurally weaker edge but rather that is more prone to chipping because it has more friction on the bite and release which places more stress on the edge.
This is similar to what I do.Draw filing is an inefficient way to sharpen an axe. It puts most of the file out of use. It removes material slowly. And it makes it more difficult to form the gently rolled edge you want on an axe.
A single cut file is useful for cleaning up the marks left by coarser files. I will shape the edge with a second cut double cut file. Then I remove the marks left by that file with a single cut file.
Nice one! Don't suppose you found an easy way to shape that rock?I'll go even more minimalist, with the provision that I don't frame my work with axes as "field work", if anything it would be the "work site", just for the sake of clarity. Spit, yes, strop with the palm of my hand or better yet, since sweat is acidic and not good on edges in the long run, belt. Especially since my puck disappeared that one day I was out working with the dog. Oh well, it'll turn up one time or the other. Also keeping a honing stone at hand, yes and in a real pinch a chip off my used up grindstone shaped to fit the hand.![]()
Thank you garry. It's been a while so I have to rely on a generalization by way of how I maintain stones over-all for an answer rather than the particular instance. It involves relative little grief in fact, first taking a hammer to the spent stone off my grinder - such grindstones around these parts are ubiquitous anyway and still being produced. Better make use rather than just let them gather moss - choosing a piece of the shattered stone that fits well in my hand and then refining the shape by rubbing it on a simple cast concrete paver with coarse carborundum grit and a few drops of water. This turns the rough facets of the piece into a slurry fast, which is the nature of an effective natural sharpening stone, that is to say, that it is friable.Nice one! Don't suppose you found an easy way to shape that rock?
Probably 1% or less of the people on this forum would ever use any axe or hatchet they own enough to have to sharpen it more than once ever few years, maybe even five or ten years. Get a big bastard file and shape it up, then get a nice fine smooth file and make it look pretty, and then put a stone on it if you want to make it look prettier still. If I was touching an axe up that I wanted to use quickly then any reasonable file close at hand would do it fast and quick and simple. Most of the knives, axes and hand-saws you find laying around that are sharpened down to nothing got that way because whoever owned them did not wear them down working with them, they wore them down because they were bored idiots with no idea what they were doing and nothing better to do than ruin tools.
