Simple Steel?
I was at Home Depot last night and while looking around I saw they had some pieces of stock there. I was thinking about picking up some of it to play around with to practice putting bevels on. I was trying to figure out what kind of steel it was but it was all just listed as "simple steel". Anyone know what this might generally be? I was assuming it was something along the lines of a 1080 or something in that area but wasn't sure.
Also other than using it for practice is that kind of steel worth anything to actually make a decent knife out of or is it not worth using for anything other than practice?
Fletch, the steel you saw was probably A-36 or 1018 mild steel. Not a hardening steel. It might be alright for practice, but won't make a blade. I wouldn't waste my time. Just get a high carbon steel and actually make knives. A local spring shop could fix you up with the appropriate steel.
Have fun.
Alden
It's 1018 (usually) or called mild steel by most of us. Main knife uses are jigs, fixtures and fittings on blades. Takes a nice bluing or rust browning.
It is likely mild steel - not useful in the production of a knife. It is probably also not the best for practice. It will still wear out belts almost as fast as a decent (annealed) steel. Cheap practice can come from paint sticks or lath. They are cheap - practice is faster and they don't eat expensive belts so fast.
Rob!
