Sinn U1
slimshaneee
Feedback: +175 / =0 / -0
This one is gone!Total redo on this post. New pictures. Price and description.
shipped. Paypal fees covered by me. Shipped via USPS priority with insurance.
Not looking to trade. Usa only.
Worn a little, changed the bracelet a few times. I see no evidence of it besides on the clasp of the bracelet. It is cut to fit a seven inch wrist and will not go bigger without a new set of rubber straps.
Also included is the four ring black zulu, and 2 ring bond zulu strap.
The warranty is transferable.
• Case diameter (mm): 44.0
• Case thickness (mm): 14.3
• Case metal: Submarine steel
• Case back: Solid
• Tegimented: Bezel only
• Winding: Automatic
• Manufacturer's limited warranty: 2 years
The technology and design elements used to create the Sinn U1 go far beyond standards used at most watch companies.
The U1 case is made from the same steel that is also used in the construction of the outer hull of submarines. The steel was procured by Sinn from a steel supplier to Emden GmbH, one of Germany’s North Sea shipbuilding yards who construct submarines from the very same steel. This special steel is also amagnetic which means that is does not have magnetic properties and cannot itself become magnetized. The watch movement itself is protected from magnetic fields up to 4,800 A/m.
Because of the special steel used from the submarine steel manufacturer, the case resists the effects of exposure to salt water and salt water environments.
The uni-directional ratchet operated rotating bezel is also milled from this submarine steel and is Tegimented. The indices are machined directly into the bezel without the use of bezel inserts, which can corrode or come loose at deep depths. The international testing lab of Germanischen Lloyd has tested the U1, and determined that the watch can be certified as water resistant to 1,000 meters. This same firm tests submarines for their ability to withstand the effects of underwater use.
Matte black dial with date at 3, Super Luminova on hands and markers, and striking red seconds hand complete the design. Other features include sapphire crystal with anti-reflective coating, and silicone rubber strap with double push deployant buckle and fliplock safety clasp.
I wore mine U1 today. It is, by far, the most legible watch I've ever owned. Best lume too. I love Sinn watches and have owned many. Free bump for a great watch at a great price.
Totally revamped the post with a much better description. And the best pictures I could muster.
