BogdanS
- Jan 11, 2015
Hello dear friends,
With God's good will today i present you a novelty in our portfolio - a full size, titanium frame lock folder - this will be the main model we will be offering from now on with few variations/customization options - 'Skiagusta' Ultra Slim+Ultra Light clip point (Custom +)
This will serve as a 'handsome' workhorse with classic lines and minimalist appearance; with only necessary 'complications' this design aims to eliminate as much as possible the possibility of failure.
Built around a titanium 'core' this folder is a pure beast in it's own rights - pure performance and functionality.
An aluminium/vanadium alloy, Grade 5 TA6V titanium offers an excellent compromise between mechanical strength, toughness and ductility hence it was the choice for the frame of the folder. 1/8 thick stock and the spring with a slight recess has a very strong action (beware if you have sensible fingers
) that offers a crisp and super strong lock - 8.5 degrees face lock angle was used.
The detent ball is high quality ceramic for an ever lasting smooth action without deformations. The face of the spring lock is left rough in order to better 'grab' on the blade and assure the safety of the user (it feels a very slight stick so know if you do not like such things but i consider it an excellent small compromise for the advantage it offers).
Very nice 'click' sounds - might not be of interest but i am a 'click snob' into folders
All screws are precision machined black oxide steel, the stop and pivot pins are hardened, precision ground 400c stainless steel so no wear in there even after prolonged years of use.
The blade slides on bronze ultra thin washers - for it's self lubricating capabilities.
The blade is made using the high carbon, ultra clean and ultra hard Wolfram Special carbon steel at 64 hrc (beware it is not rustproof but you know me - i am the carbon steel guy
- might offer stainless alternatives in the future but not sure yet), with a high flat grind and satin finish. The blade comes razor sharp.
The blade is nicely centered and the knife can be flipped (to some extent) even though it is not meant for that but to be a tight and tough user.
US/UL Custom+ features on top of Standard:
- Sunken screws for an ultra slim profile of only 3.6"
- Ultra slim bronze washers again to help maintain the profile thickness to bare minimum.
- 'Thunderstorm' Ti finish on both scales and pocket clip
- custom pocket clip
- two tone blade finish
OAL - 7.87", Blade - 3.55"
The price for this one is - 325 usd
All the best, God bless,
Bogdan
Bogdan
