Skills:PSK (ITEM 7 IS UP!): A Group Exercise in Creative Thinking and Improvisation
Not sure if this has already been posted as I haven't read through the whole thread yet but...
Hook and line: grind off barb and stitch up a gash in arm or leg. (hope you have a stick to bite)
Aluminum foil: use to collect condensation from early morning dew. Signaling device?
Sorry if I reposted anything thats been said already.
Brian, these brainstorming exercises can be quite productive. :thumbup: Okay, I have a few minutes to jot down some ideas.
If the fish hooks were ferrous, one might be straightened out and used as a compass needle. There should be some finely coiled copper wire in the radio speaker, as well as a magnet. If the magnet could not be recovered, the wire could be combined with the battery, it could be used to make an electro-magnet to magnatize the compass needle.
Copper wire and fishing line could also be used for lashings for bird traps or other small devices that have multiple parts that need to be attached. Likewise, they could be used to lash together a shelter frame.
The wire and the battery could also be used to ignite some tinders, and possibly make a "hot knife" for cutting styrofoam or similar.
Hooks could be lashed to the antenna to make a snagging stick to retrieve critters (mice, scorpions, etc) from their lairs. Plastic from the circuit board could be sanded sharp on a flat stome to make a cutting tool.
Foil can be used to make a signal mirror. It makes a lousy water container, but if it's all you've got, do what you've gotta do. It could make a lid or a funnel if needed. It could also be fashioned into into makeshift sunglasses as well.
Okay, I'm starting to critique as I go, so I should stop.
-- FLIX
I'll try to only say new stuff.
Hook, line and sinker: use to clean teeth(think toothpick and floss)
Foil: strips for trail marking, mold into sunglasses(small slit to see through)
Radio: if its an older radio it will have a a lot of wire to use for whatever, use the small components as lures, use shell as a trap for small bugs, use shell as contaner to hold other items, antenna blowgun, antenna drinking straw, antenna kubaton, small metal part to make compass
Thanks, Flix - I agree! We're getting great stuff here! Next Item!!!!
A flashlight. Can be handheld, or headlamp with straps.
Shelter:
Fire:
Water:
Food:
Be creative, and don't be afraid to dream up anything! It just might work!
Remember, we are not combining items yet! Just that one item, plus natural materials you may find. So, now you have a flashlight, but no other tools. Feel free to continue posting ideas about any previous item. Also, so you can find the previous listed items, I've added them into the original post.
Flashlight
Shelter:
Fire: The lense could be used to focus sunlight for making a fire.
Water: Take head and batteries out. Use like a cup for catching rainwater or dipping from water source.
Food: They are kinda heavy right? Throw and hit a critter in the head (flashlight or batteries). Just don't lose it. If the lense is broken, it could be used as a knife for skinning small game.
With the flashlight (I'm thinking of a maglite-style flashlight instead of a headlamp):
Shelter: use flashlight cylinder as a joint between two smaller sticks to strengthen a weak center pole (assuming wood is scarce and nothing big 'n strong is available);
Fire:
unscrew the plastic part of the lens, gently take the bulb out of its socket, and then use two wires (yeah, I'm cheating slightly) to start a fire. Place one wire in each of the bulb holes, ready your tinder (preferably pitch/fatwood) and then twist the two small wires together, completing the circuit. Then, hold the connected wire ends, while still in the flashlight, in the tinder. It will form a charred area, which can be blown into flame. It's necessary to have a LOT of tinder; lens may be used with sunlight as improvised magnifying lens, heating up tinder
Water:
if necessary, use the gutted flashlight tube as a drinking straw for hard-to-reach water; use tube as a funnel to aim streaming water into a container; many flashlights are water proof or resistant, so empty the tube of its contents, leaving the bottom sealed, and use the metal body as a drinking vessel. Since it's metal, it could be used to purify water in a fire, too. However, this would melt the rubber gasket that's usually found at the ends of a flashlight
Food:
the flashlight body, especially on a larger light, could be used as a small cooking pan (stuff the grub in and stick it in the fire); aren't fish attracted to light? Use the flashlight at night as a fishing lure. Yeah, I've had very little fishing experience
non-specific use:
the ends of the metal body could be sharpened to cut with, especially if the tube is flattened first
Aluminum foil use: Rescue Riley got me thinking. He mentioned how tin foil can make a cool robot mask :D Well, in a very sunny environment, the foil could also make a sun-block mask. It'd work to keep direct sunlight off the back of the neck, also. I wonder, though, if the skin would eventually overheat and start to cook? :confused: :eek: Perhaps it could be used for a few minutes at a time, then taken off temporarily. Ultimately, it'd cut down on sun exposure. And, you'd look like a cool robot, should a rescuer find ya :p
If the batteries are dead, maybe the reflector could be used as a make shift mirror for signaling.
Maybe the reflector could be cut down and used in fishing as a lure.
once the batteries are dead, i suppose they could be removed and the body of the flashlight could be used to store small items that need protection from water, or being crushed. joe
Cut a slot in the flashlight where the two cells meet. Run a string between the two cells so that they do not connect.Turn it on. Now secure the string on both ends in a path. Anything coming down the trail will trip the string causing the two cells to connect and the light coming on. Or use the same setup as a fish strike indicator on a pole line.
Good stuff!! Okay next, a small razor blade like this one:
4424
:D
A razor blade ust like that one, eh? :p
Fire: scrape shavings of pitchwood for tinder or feather a stick for tinder; shoot sparks from a firesteel
shelter: make slicing cuts in branches to be able to break 'em, making a shelter frame; cut big leaves and small, leafy branches off of tree for insulation
water: hmmm... whittle a branch into a cup for holding water (yeah, it'd take a long time)
food: cutting traps 'n snares: nothing branches for a Figure 4, etc
Basically, this can be used as a replacement knife in various instances.
Razor - Slash your wrists because Rosie Odonnell was the only other survivor of the plane crash - and she's looking hungry!
-- FLIX
I haven't had a chance to jump in yet - great thread Brian. Reckon I'll print and save it when it's done (in about 12 months)
Razor blade eh?
1) Heliograph
2) Thin slicing reeds to make line
3) Cutting clothing for simliar uses
4) carving fish hooks/barbs
5) Making wood shavings
Flashlight:
storage container, ground trap for bugs, drive into a tree as a handhold/step/hanging hook,
Razor:
regular knife stuff, Shave so you look spiffy,
It's slowing down...I think everyone is getting tired of this thread, LOL...:D It'll pay off in the long run if we keep it going, I am confident of that. :thumbup:
