Wayfinder. Great videos. Thanks for posting.
That's one reason I'm not a fan of the rounded spine on NM knives. Give me my sharp edges back!
To each their own, but for "Knife" use, I way prefer the rounded spine. :thumbup:
The "One-Handed" fire starting method is nifty and all and I guess it requires something like a knife with a squared spine or edge to be used. But, I will just probably have to assume I will have use of both of my hands and I think I will stick to prioritizing a knifes spine for "comfort function". I don't use my knife as a striker. I don't "expect" I will need to. So, I have no need or want for a sharp spine.
I know a LOT of guys want to use their knife spines as a striker for ferro sticks, but if you are going to bother carrying a ferro stick, why not a little dedicated styker. There are MANY dirt CHEAP and light-weight options.
You can find little dedicated strikers for about a buck or two.
I haven't tried yet, but I always thought one of the "tungsten Carbide" Sawzall blade for cutting tile and such would make a great ferro striker:
The Tungsten carbide "Teeth" should create a ton of sparks and last a long time. :thumbup:
A Sawzall blade already has a hole that you could run a lanyard through, you could grind off the little tab point and then grind the whole thing to the size and shape you like:
..... or similar..... Put a little bit of Electrical tape on the handle area (optional - if you like) and done.
Or just simply grind the back of an OLD sawzall blade at a sharp 90... whatever.
Or look into a "Blast Match" with integrated striker, etc. etc.
Maybe just me, but ANYTHING other than unnecessarily bunging up my knife.
I would personally rather have my knife left "Optimized" for "KNIFE" use. :thumbup:
Using blade "edges" as a striker is silly to me. Sorry. I wouldn't used my blades edge unless I absolutely had no other option. The ferro rods DO dull the edges and while it may not hurt the steel much, now you have a dull edge "In the Field" and have to spend that much more time sharpening at some time or another when you could have just used a CHEAP and EASY to carry striker... But, that is just my opinion. Obviously, many seem dead set to bung up their knives and feel carrying a "0.5" ounce striker to be a hassle or something (????).
I have used a few various Ferro rods. They work. I have tried/done and know how to use a few different "emergency/survival fire options to create fire "IF" and when needed. But, I don't view every fire as another need to test my survival fire skills. Let alone another opportunity to unnecessarily bung up my knife.
Call me lazy I guess, but I typically just take the easy path on some of this stuff. I always seem to have a small torch lighter of some sort. It works without bunging up my knife as well.
I use "TOOLS" a lot. There is a common saying for those who like and use tools: "Right tool for the job".
While the Busse Nuclear Meltdown is pretty good with me, I actually have a slight preference for my spines and even choils to be just slightly convexed with radiused corners - like in the lower left:
But, I don't mind the Nuclear Meltdown either.
