I pulled out my 0561 today and after using the skyline this week, I appreciated the IKBS even more. It doesn't take any effort at all to get that big old blade to fly out on the 0561.
Kershaw should start using IKBS on the skyline, and all of their flippers for that matter.:thumbup:
Not only should Kershaw start using IKBS on everything, they should make a black/coyote fixed skyline! :thumbup:
Bearings smhearings.I pulled out my 0561 today and after using the skyline this week, I appreciated the IKBS even more. It doesn't take any effort at all to get that big old blade to fly out on the 0561.
[video=youtube;f0fB9FBYiZ0]http://www.youtube.com/watch?v=f0fB9FBYiZ0&feature=plcp[/video]
My observation is that the finish on the blade is a major contributor to how smooth/fast a knife is. My stonewashed knives are the smoothest while the satin knives with grind lines you can feel are the least smooth. I imagine once the detent ball wears the coating down it will get a lot smoother and faster.Yeah see, that's how I've seen other skyline's deployed, exactly like that zing....I can achieve the same results with the up/down technique, but I see there, you're simply actuating the flipper.
Tightening or loosening the pivot screw, tighten it to move the blade left and loosening it will move it to the right.
Quick update; after working the blade a ton, moving the blade back and forth, rubbing the detent, the dlc coated skyline is becoming buttery smooth. I can tell that with more use, it's only a matter of time before the blade locks up with quick use of the flipper. It already locks up fast with just the slightest little flick of the wrist. I love the black/coyote skyline...
Kershaw, keep the limited runs coming, lets continue to see different colors. It would also be nice to switch up the blade steel like that of the blur. 154cm, s30v, damascus, would all be perfect! Same goes for the fixed version as well. I have no doubt that they would sell like hot-cakes. Also, if you could incorporate some jimping on the blade, or handle, or both, it would be even better!
forum skyline is s30v, and they have already done a run of damascus with another one coming "soon". i would love to see a composite blade with something really high-end though. elmax anyone?![]()
I think you just need to work on technique. The main thing is you have to build pressure on the flipper by pushing up and in so as not to deploy and then when you have enough pressure built up you need to snap your finger down.
If it is done correctly and the pivot is not over tightened it should fly out with no problem.
