RokJok
- Oct 6, 2000
My guess is that gloves don't lose the heat, they prevent it from being generated in the fingers initially. The physiology of the vasular system reinforces the idea that the extremities (fingers & hands included) are the expendible parts of the body and will be sacrificed if needed to keep the core warm. The blood vessels in the fingers are small, e.g. not built to deliver gross volumes of blood & heat. Thus, anything that restricts the blood flow through the fingers (not a hard thing to do) will seriously impact their ability to stay warm.Originally posted by TLM
Dressing inside a bag is more like using gloves INSIDE mittens, nobody has yet explained how that would lead to MORE heat loss, I would like to see a better explanation.
To fit the hand at all, the fingers of gloves must be to greater or lesser degree snug each finger. Thus they are squeezing the surface the fingers, which restricts the blood flow. The thicker the insulative layer is built around each finger, the worse this squeezing gets.
With mittens you don't need to maintain any degree of close fit to the surface of the hand, since fine motor skills in mittens are non-existent.
The advice from Terrill and Nathan to use a hat is some of the best. A polar fleece watch cap weighs only a couple of ounces. But it can make a HUGE difference in how warm you sleep (or hike or stargaze or dash out for the midnight tinkle), especially as the temperature outside your sleeping bag falls past the point at which you can normally sleep comfortably in the bag.
Coyotlviejo, thanks for the tip about using a shirt around the neck as a surrogate shoulder draft tube to block warm air leakage. Now I can stop strangling myself with the pull cord trying to keep that warmth inside the bag.
