I'd sure like to see what you're working on.
A sleaveboard apparently.
MOP handles, tip bolsters, vintage German, nail tool on the bottom...
How about a couple of hastily-taken snapshots... on the floor... with the wrong lens and no lighting. Still better than my drawing skills.
Sorry for the time delay due to the time difference. I had suggested a sketch as I thought we were talking about a knife being made for some reason. That's a Sleeveboard Lobster, and a nice one from the look of it :thumbup:
Are we sure it's a sleeveboard? It looks equal-ended from here, but perhaps that's just the camera angle.
Nice, regardless.![]()
It does taper, making it a sleaveboard.
So it's the extra blade/tool on the bottom that makes it a lobster?
The maker is Bruckmann, btw. And the incredible m.o.p. is deserving of a real photo some day.
SLEEVEBOARD :thumbup:
It's the fact the blades are on a central spring/springs, and the fact that it is of a small size, which makes it a lobster :thumbup:
I would like to see more pictures![]()
Primble, I love that sleeveboard!
The taper along the sides needs to be straight to make it a sleeveboard
GREAT info Mr. Jack ! I put that in my notebook.:thumbup:
Sleeveboards take their name from the small ironing boards used to iron the sleeves of shirts, they can be jack knives or pen knives. Lobsters have blades coming out of both sides of the knife, with a central spring or springs (in the case of more modern lobsters), and can have as little as two blades. There are a number of different classic lobster designs, including the sleeveboard lobster.
To this gentleman the trade is indebted for what is called the lobster knife, consisting of a spring, which instead of forming the back, as in the old method, is placed along the middle of the handle, and between the scales or sides of the knife, so that it works on each side, and hence admits of blades at each end, and even of any number of them. The mode of slitting the spring gave rise to many bladed knives in all their varieties.
Traditional lobsters use Crawshaw's fragile single slit spring, but modern machine-made versions use a pair of more durable simple springs tabbed together back to back. Because its spring or springs are in the middle, a lobster pen knife always has its pivot pins set off to the sides of the long axis of the knife - hence the resemblance to the waving claws of a lobster.
Lobster pen knives are flat and lightly built...
