Quote from KennyB
"I agree with you and see where you're coming from, but I don't think it really makes the TP test any less useful. I mean, I don't think hair splittings is a very good test methodology anymore either after some of my own recent results that would split hair but wouldn't shave. Then there's the fact that hair varies in thickness, hardness, color, and even the condition. Any time I went to pluck a hair out of my beard, I would have to make sure it was a thick black one with no cinks in it so that the testing was consistent. At least with toilet paper ( regardless of brand ) you're using a testing medium that is a lot more consistent."
KennyB,
Would you mind sending forum members, that would like a constant testing medium, some of you thick black hairs with no kinks from your beard?
This way we can compare hair to hair to find the sharpest edge.
This is a good discussion on sharpness and cutting ability. I have tried some soft two ply TP with poor results. (My wife's TP of choice) Yet the same knife will send hair flying off my arm and whittle hair without a problem. Would not the blade material, angle of the edge and
Your Technique among a few other variables also play a part in your testing for the sharpest edge?
Find the best way for you to test each of the knives you sharpen that works best for you. Just my 0.02[/QUOTE]
My sarcasm meter might be way off, but I don't think it's a good idea for two reasons 1) I'll run out! 2) I don't think they're a consistent test medium.
Even on the hairs that I can pick out by hand and judge them to be pretty much similar, the diameter varies by almost .0005". That's not a big variance, but I think when we're talking about the scale of a knife's edge apex it is. If I remember reading the Verohven studies correctly, most of the edge apexs were .0034", so I think a variation of that much would probably make a pretty big difference.
pwet,
That was my first thought too, but both sides cut just as effectively, and I even checked it out with 30X magnification and couldn't see anything, and spent some time stropping it, a couple of passes with extremely light pressure an an exaggerated angle to knock the burr off if I just couldn't see it, and it pretty much remains the same. It's one of the most confusing results that I've ever had, because by all of the tests I perform it should be able to shave just fine, yet it doesn't.
I think it just shows that whittling/splitting a hair can be done at a lower level than is usually thought unless it's done with the right technique. For example: If I hold a hair up between my thumb and index finger and allow it to stand on its own, and I run an edge along it and it takes a fillet out, I consider that truly hair whittling. However, if I can do the same thing, but start with the edge as my thumb as the backing to keep the hair from moving, I consider that whittling/splitting, but it's a lesser form since I still needed the hair to be kept stationary the slightest bit--a very sharp edge will just grab it. Then there's the "almost whittling" results I've seen where you kind of have to press into your thumb as the backbase a little before it will cut. All three of these levels will shave my hair, and I've seen them on anything from 1000 grit edges finished with CrO to factory edges that were probably finished at 325 grit and a buffing wheel.
To me it's more a matter of technique. If an edge isn't sharp enough to just grab on to a hair and slice it up, then the user might figure out a way to angle the hair to put more pressure on the edge, but that's the point at which the technique deviates and the results become somewhat meaningless.
At the end of the day, I use to use the hair splittign/whittling test as a, "Well, if it's that sharp, it will do anything I want it to including shave my face." I still think it works as a way to see if it's there without actually busting out the shaving cream, but it really doesn't tell me how sharp it is at all. I essentially work until I can shave my face, and call that good... How "sharp" that really is compared to anything else is something I don't think any of us an honestly determine because once we're talking about the scale where we're whittling hairs, then all the little variables like technique, edge geometry, environmental conditions, hair consistency, etc. have a magnitude more influence over the result of the test.
However, I still think they're pretty useful tests. If I can pull a hair out of my beard and whittle it, 90% of the time that means I could shave with it, and do pretty much anything else with it as well. In the end though, I can do the same thing by seeing how much the edge bites into my finger, and it would save me pulling a beard hair out... So I think a little bit of this testing is vanity, at least for myself personally.
