slip joint blade sharpening choil or cutout
HSC ///
Am going to spend most of October refining my skills on slip joints,
one thing I've never done well is the sharpening choil angle cut at the beginning of the blade edge.
Anyone care to guide me as to you setup to get a consistent grind here?
What step of your process do you grind this relief In?
Here's one I just completed, obviously I didn't put in the sharpening relief...
thanks
I just use diamond files when I need to add a sharpening choil to a hardened blade :)
~Chip
I hold the blade in a vise where the plunge is exactly vertical and start the choil with a dremel cutoff wheel in my flex shaft. Then use half round needle file. The cheap harbor freight files vary thickness along the edge. You want a file with a good consistent edge, and preferably no taper or at least a long section that is untapered.
On your platen at the center height of your work rest grind a cutout at about a 45-60 degree angle with about a 1" small wheel. Leave about a 1/16" from front of platen for future surface grinding of platen face. Do it on the side opposite of the tool arm for more clearance. I do them after heat treat and blade is ground. I start with a 120 j flex and normally finish with a 400 j flex.
Great idea!
I normally use a triangle file, or even a small half round. I'll rough notch with a band saw, then refine with one of either file.
Maybe a bit on the side but I always wondered why classic slip joints usualy have a triangular notch.
Why triangular, why not half round?
