SBuzek
Basic Member
- Dec 7, 2006
Ok, I'll try doing the pivot pin like you said. I am worried about peening it too tight. My spring is about .005 thicker than the blade. I guess i can stick a scrap piece of steel inside the handle to help from peening it too tight?
Your blade and spring must be the same thickness or you will bind the blade when you peen. As you peen the pivot pin it will lever off the spring and form a clamping action on the blade, I make my springs .0005 less than the blade.
