- Mar 12, 2013
Hey guys!
I'm trying to work out what the best method is for heat-treating small batches (around 4-5) of A2 knives in my shop. These blades will be air-quenched.
I have an 18" Evenheat kiln, and the main thing that I'm worried about is line-of-sight heating from the coils, as I understand it if I have several blades in the kiln with the blades vertical then the outer blades will likely be over-heated as they'll be directly in sight of the elements... Those outer blades will cast a shadow onto the inner blades and therefore the heat they see will be different.
Is this really an issue? If so what is the best way to deal with this? Some sort of steel/refractory baffle in between the knives and the elements?
I'm also thinking that I need to come up with some sort of fixture for handling several blades as a group. I was thinking something like this:
This would let me pull 4-5 blades from the kiln in one go and then hang them to cool. Any thoughts on this? I could handle the blades individually as well I guess, I would still need some sort of racking (like the rack that evenheat sells) in the kiln. I'm curious what you guys generally do for this sort of thing.
Any input is appreciated!
-Aaron
-Aaron
