How about a
Spyderco Dodo
it's an unusual looking knife, that's for sure (some have called it ugly, hideous, bizzare), but it's a knife that has to be *held* and *used* to be fully appreciated, the blade is around 2" or so, but the Reverse-S blade design has a lot of cutting power, in short, it cuts like a much *bigger* knife, the G-10 handle is grippy and gives you a confident hold on the knife, and the grip layout fits the hand *perfectly*
everyone i've let try out the Dodo makes the expected remarks about it being "ugly", but once they open the blade and put it in their hand, they immediately understand the reasons for it's appearance, they then generally remark that it's the best fitting/most comfortable knife they've ever held....
there's no better example of Spyderco's "designed in the dark" philosophy, ergonomics and functionality are the primary concern, appearance is irrelavent
problem is, Spyderco's discontinued the Dodo and supplies are drying up, get one while you still can....
then you can join the "Cult of the Dodo"
Anyway, I found so many uses for that thing that I want to get a really nice knife to carry with me. I want a knife I can use for everyday tasks, that will hold up and stay sharp. Mundane stuff like scraping paint, trimming tape, scraping plaster off molding (doing a lot of rennovation on our house) stripping the odd wire, cutting open blister packaging, plastic bags, etc, etc. A knife I can *use*.
as far as the scraping duties go, a paint scraper would be a better choice, but everything else the Dodo could handle, it would excel at trimming tape, cutting open blister packaging (that little hook at the front of the blade does wonders on clamshell packaging), the serrated model would work well for stripping insulation off wire, just put the wire in one of the serrations and peel off a layer of insulation
the only thing the Dodo really woulddn't be good at is anything needing a "stabbing" motion, or scraping, the curve of the Reverse S doesn't really lend itself to scraping duty
