Small Fishing kit for PSK
I'm working on assembling a small fishing kit for my PSK. I was wondering how you guys have packaged yours and what # of stuff/contents yours contains. Do you guys have any lures included due to bulk constraints? Pictures and ideas extremely welcome. Thanks - DS.
No lures in mine. I concentrated on smaller, panfish size hooks, as they are most prevelant in the streams and lakes here in TN. I put in a few sinkers, little skinny cork bobbers and a bunch of line. I went with the spiderwire since it is extremely strong and works well for snares and lashings as well. In addition I carried a nate that has been sharpened on both ends with one end bent at a slight angle. This can be lashed to a small diamater pole as a spear point for fishing as well. This nail is wrapped in a bunch of spiderwire.
I'll see about getting some pictures in a bit. Gotta take some photos of some old knives for another forum.
Later,
Charles
Inside a 35mm film canister.
(Need to add 1 or 2 wet flies)
50' Fishing Line, nylon, 20 lb test
18 Hooks, 3 assorted sizes (6,4,2)
3 Swivels
8 Sinkers (split-shot)
2 Floats
I keep a telescoping rod in my bag, with a spincasting reel, hooks (I keep sizes 2, 4, 6). The reel I I have on it right now is an inexpensive Shakespeare, loaded with 6 pound test IIRC- and it will work for Panfish, Small Cats, and the bass that are local. Works for trout to. Small cats stretches it for that tackle- but I have fought the fight with them. If I intend on going for cats, I'll throw my 404 reel on. I use bullet weight non-lead sinkers. I generally don't use artificial bait- fake bait if you may. My luck really hasn't been so good with it. I've got a couple new lures, maybe they'll work. I prefer nightcrawlers- those can be found pretty much anywhere. I dug bait on site once- it's doable- especially if your not picky on exactly what your looking for. That telescoper has become my favorite fishing rod, in all irony ;)
I used to have a small pocket kit- hook, line. Not sure how practical it would be, never caught anything with it. I planned on digging bait to use that. Only tried it once, and that was very brief- not a good exhibit.
There is also some small reel like devices that some suppliers, ie Cheaper than Dirt sell. Theirs mixed opinions on those. I haven't tried themn so I can't say.
I also intend on trying at least one of the float methods described by Wiseman as well. That would definetely be field expedient, requiring hooks and line to be carried in, and a float carved from wood inthe field.
3 Swivels
2 Floats
Good tip about the 35mm film canister, could also spool some duct tape aroud it too...
I fish quite a bit as a hobby so I have narrowed my kit to what works in a wide range of places. As far as lures I carry a couple of flys and nymphs and several jig spinners, also known as beetle spins, they are very cheap and very effective for catching fish to eat and small fish to use as bait both for snares and bigger fish. I also carry 2 very large hooks that can be used as gigs or gaffs when tied to a stick even on small game. As far as digging bait an easier and more effective way to get bait is out of the water you are fishing in, wade around the edges turning over rocks and sticks will often turn up crawfish, lizards or bugs that make excellant bait and are natural to the fish. I carry 4 different lines 15LB for limb lines and trot line drops, 6lb for general fishing, and 80 pound spectra for snares and the main line on a trot line and last a spool of dental floss which can be used for fishing and making drop lines, limb lines and trot lines. Here is a pic of my PSK and fishing kit.
And non survival fishing.
In my main ruck, I've put together 2 Altoid tins with 50' of 12# spyderwire, 25' of 8# leader line, 20 assorted bait hooks, 10 small gold treble hooks, dozen flies, 10 split shot, 2 small sinkers, 6 jigs, 6 gold and 6 red beads, small bobber, 6 small swivels.
In my EDC, I stuffed a few flies, a few gold hooks, a few split shot and 50' 12# spyderwire into one of the compass topped match safes.
runningboar - good pics and nice kit! What is the fishing line spooled around a super glue tube? What is 80 pound spectra? Why is it that all you army guys like watersports and us navy guys like land ones...Did do some fishing off the fantail on deployment though...
Longbow - good idea about using the match safe and having a backup compass. I like that even better than the 35mm canister.
Thanks guys - DS
In a small (tiny) ziplock bag I have:
- four #6 hooks
- three medium swivels
- four small split shot
- two small safety pins
- one medium safety pin
- twenty feet of 20lb line
and in the PSK: a metal bobbin with approximately 50-60 feet of nylon upholstery thread. I don;t know the pound-test of this stuff but I can break 20lb test line and I cannot break this thread.
The line on the superglue tube is 6lb silver thread, spectra is a brand name of fishing line http://www.tacklewarehouse.com/descpageLNEPOWPRO-PPSL.html. I didn't picture the spectra because I used the last I had to sew up the doors on my jeep, I have to get some more.:o
As far as watersports I love anything outside but I really like canoeing, hunting and fishing, I guess you navy guys see the water so much your sick of it.
I've posted about this in the past...
One of the most effective small fish lures (bream, small bass, crappie) is the popping bug.
I've read in F&S that some military survival kits include the simple bucktail jig.
Do you fish? That the starting point, I think. A lure is only as good as the amount of confidence you have in it and skill you have with it.
If you can scrounge some feathers or hair, light wood, a hook and some string or thread they are easy to make also.:thumbup:
EDIT: I just read through your thread and you already said that.
You also mentioned that a spinner is effective but requires a retrieve which is true. Since you use popping bugs I assume that you fish with a fly rod, in the wild if you have a flexible limb, bamboo or cane is perfect, safety pins to use as guides you can build a fair rod that will cast and retrieve. I always have safety pins in my kit for this purpose as well as anything else you might need a safety pin for. Chris
Fisherfolk -- what do you think of including a jighead or two, if space is extremely tight even instead of hooks/sinkers? You can always tip the jig with the bait you'd otherwise use, but then you also get the benefit of using it lure-style with perhaps found materials.
If you look at the small bag in my pic I think you will see a couple, they are bare but I tie my on flies and with feathers or fur, even some of my own, and some floss I can fashion a jig quickly. Chris
Indeed. texascarl posted what I thought was a good response regarding "dapping"--a term I'd never heard, but something I've certainly done with a can pole. See below.
Would be interested in seeing a rigged rod using safety pins.
Let me add my vote for popping bugs. Over the years, probably the most productive lure in my kit. For those not used to them, timing is everything. They work best near sunset or after, IMHO, on still water. Without a fly rod to make them do their best magic, just use your pole to 'dap' them along surface, as if they were dragon flies or something similar flying close to the water, touching down now and then near a stob or log, lily pad or other cover. Be prepared for explosions. When I was a kid, after ruining a 'thumb-buster' reel and being denied access to Dad's expensive gear, I learned to wade the creeks with a few poppers, some 12 lb mono tied to a long, whippy willow or cane pole and bring home tons of bass and bream. Dapping is like fly fishing, but without a reel. Not a lot of huge fish, mind you...but rural kid popper fishing and survival fishing have this in common, quantity counts! And the occasional large fish still came my way. Wait until dark, use that same short stout string and long limber pole, remove the popper and attach a stout snelled hook baited with a limber strip of pork rind cut with a split tail that immitates a 'frog'...or use a similar strip cut from the belly of another fish. Walk along deep water (dam faces or 'fishing holes with good watercover) and 'slap' the frog along the surface in the dark. Splash it around like something wounded, you'll bring out all the benevolent members of piscatorial society. You might be surprised at the charitable monsters that you can yank out of small streams and ponds this way. Give me some poppers, a few hooks some mono and a frog gig head, I'm good to go. I'd probably miss my 6 weight and/or my ultra light spinning gear...but I doubt if I'll get hungry. Let me add that a few of your popping bugs really should be red...you can always catch frogs on a red feathered lure 'skittered' near enough for your bufanoid to get annoyed.
I've done a decent amount of fishing with a traditional tacklebox both in fresh (mostly in MI & WI lakes and rivers) and saltwater. I am not a novice but certainly no pro. I have never fished with out some sort of rod and reel. I am wondering has anyone fished w/ an improvised rod & no reel (i.e. W/ what's in your BOB or PSK?) Maybe this is something we should all try along with other bushcraft skills...I know runningboar is up to the challenge...
Take a safety pin and bend it at a 90 degee angle, use waxed dental floss to attach it it to your pole, I don't know the name of the knot but it is just like whipping a rope, when you wrap a loop and then pull the free end under the wraps. Tie on about 3 or four bent pins in a line just like guides, run your line through the safety pin/guides and tie it to the butt of the pole, be sure to leave enough slack for casting and retrieving. Anyone that fly fishs will get the idea, it is just like stripping line off your reel and letting it gather at your feet for casting. I only reel my line up when I am going to move most of the time it lays in the floor of the boat or at my feet.
Stiff line, like fly line, works the best for this technique but I have done it with 15 pound cajun line and braided line, with a leader attached in both cases. It tangles easier than fly line and I can't cast as much or as far but it is better than just tying your line to the end of the pole. Chris
runninggboar--- great pics....:thumbup: nice kit there... :thumbup: i need to put more effort in my PSK fishing kit..... there is some great info here so far...
i too am curious about that container... and what kind of neck knife is that... it looks like a BM snody....
mike
