Small Full Tang Utility
Feedback: +7 / =0 / -1
Hello again,
For those of you whom I am working on your knives, I am working on them. At times I like to take time out and play.....
These are users and nothing fancy about them. The handles are made of Corian. They can be a little slick in the hand (not if it is bead blasted), but a good grip is all you need. The blade is 1084 and 1/8" thick. The pins are brass 1/8".
The finish is 320 grit plus a hit or two on the buffer, then I bead blasted the blade only which shows the quench line well. The bead blast will hold oil well. Just maintain it as you would any other blade.......
Measurments are appx.:
5 7/8" total length
3 1/8 handle (corian)
2 3/8 cutting edge
1084 steel 1/8"
edge quenched, tempered twice.
brass pins
ivory will be posted later today I imagine
pics are of green and sand
Cost is $100 in the US
That is one draw back of the corian, yes,,,,,,a little heavier because the material is dense. but it gives a wide variety of looks..........
The handle is not bead blasted only the steel is. No pics of the sheaths, made after sale due to not everyone is right handed......... if you want to see one of my sheaths look for my damascus skinner on here......
