man, thank you for your tests, cool.
what do you think retention of INFI that comparision with other steels you tested.
what is/are the INFI advantages ?
thanks
dingy
Infi as a steel has excellent edge retention .... there was a test done a long while back by Mike Turbor I think comparing a Basic 9 to a Cold Steel Trailmaster and on edge retention they taped off a few inches of blade near the handle and ran the knives using some clamp through sheets and sheets of cardboard .... and the ASM Basic 9 easily came out on top.
To talk properly about edge retention of a steel you need to get quite technical about how the carbides on the edge lie in the steel .... how they are layered and how they are able to remain in situ behind each other ... basically how uniform they are .... this probably explains why the best steels are now looking at a powdered format to enable consistancy in this aspect ...
My review though is showing that for simple "use" ... it is the design of the knife that makes a lot of difference .... basically the type of grind and the type of edge play a great part in actually enjoying "performance" when it comes to simple use.
I don't find out anything unusual though ... my findings basically say that a thinner and harder profile cuts more easily than a thicker one or a knife that is a bit too acute on the angle of the edge and which consequently "rolls" ... and that what can improve the "rolling" problem a bit is a higher Rc setting .... although that is not a substitute for using certain key principles .... such as a thin grind brought to a sensible micro convex bevel or secondary bevel seems to work the best ....
This goes hand in hand with what the competition cutter guys are finding with their knives .... they have thick spines for strength ...especially when chopping .... but go to a thin apex on the grind by the edge ... and are then sharpened with an edge that is convex and I bet reasonably robust in angle ...something like 18 degrees either side or 36 degrees inclusive .... so that the edge is less likely to roll but resistance wise there is not a thick aspect to the steel behind the shoulder of the edge so it can bite deep.
This is how edges like that can cut free hanging sewing thread etc ....
I guess what this cluster of knives have shown is that the one that possibly comes closest to a competition knife style .... and Itou as a maker is much more recognised as a Chef Knife maker where cutting is a "premium" requirement .... that this type of grind works best also for carving with wood ... and again .... hardly suprising... if the grind also works well on food and meat.
The thing with Infi though is finding the right knife in Jerry's range that meets this sort of spec .... there were some BAD's done to a higher Rc setting and had thinner blades .... I have'nt got one ... but I bet they would do very well in this sort of thing .... and these were sold through Skunk I think and did have the caveat that they were not meant for "leverage" work .... but would still be covered by the guarantee if they were broken.
If Jerry could improve upon the availability of thinner Infi with a higher hardness in his smaller knives or even thick Infi with enough depth in the blade to become thin at the edge and give it a higher hardness .... and simply qualify that these edges are more for cutting than prying or chopping through metal .... then I think he would be on to a winner ....
Infi works best .... as is .... in large chopping knives .... the edges don't chip out ... they roll and can be easily fixed.
You don't need that spec though for a smaller EDC style blade if your main use is "cutting" ... you can go harder and thinner behind the edge shoulder and get IMO better performance ....
Just don't use them for prybars or baton them through coins etc .... uses IMO again ... which are not meant for good quality knives you carry on your belt for cutting.
Different of course for something bigger ... hit a rock with a large competition knife when chopping near the ground and likely the edge may "ripple" .... for that reason the judges check the blades after every course of cutting has been completed .... they know these blades are right on the very "edge" of what the steel can take ....
Hit a rock with your KZ or Basic 9 or 11 or Mistress etc ... and sometimes it is'nt even worth stopping to repair the damage as it is too small .... or if there is some damage .... a quick going over the edge where the steel has rolled with a honing steel to straighten it up .... and you are good to go.
You won't do that so easily at a higher Rc setting .... much more likely to have the edge chip out ....
So keep Infi as is for the "choppers" .... and tweak some Infi for a few "professional cutting blades" ... for HOGS who want to cut stuff .... and don't need to pry etc with the blade ...:thumbup:
Great review Peter!
Great knives all :thumbup:. . . . . Nice job!! :thumbup:
Jerry
you did great!
thank you again for enlighten me.
dingy:thumbup:
Awesome review Peter!!! Thank you so much for going to so much trouble and posting here for all us knife nerds.![]()
My favourite Aussie expression ... use it all the time now .... " No worries mate"Hope to meet you sometime at one of the shows :thumbup:
