I was over at my pals for a gathering of local homebrewers so I thought I would snap some pics of his cabin.
The first section was made maybe 30 years ago when he and a bunch of people moved there and the whole property was sort of a commune. Gradually a lot of people moved from "back to the land" to "back to the city" and while the large tract is still communally owned everybody that still lives on it has their own house.
Anyway here's a pic of the house. The taller portion to the right was the old section. It has one central room and then sort of a loft, attic where you sleep. The addition my buddy built a few years back and is an expanded kitchen area. You can see the solar panel on top.
This is the right side of the house. You can see it has a foundation of creek stones and notice they didn't spend a lot of times fitting the logs together, they just used a lot of fill.
Another thing you can see as they went up and didn't have the labor to hoist huge logs they moved to smaller logs for the top:thumbup:
Also notice the floor and loft/ceiling joists sticking out of the chiinking.
See the addition sticking out a bit further. he excavated under a bit for a celler and a shower area and area for a hot water tank when he bought the gas well on the property. By making the shower area well below ground level the whole thing works on gravity feed.
On the addition rather than do a full foundation like on the old section the kitchen addition is set on concrete piers. You can also see a bit of the styraform insulation they use between the logs before they chinked them.
Above the house sets a 500 gallon plast tank buried in the ground to insulate it for the water source. The logs stacked behind the tank are shiitake mushroom logs.
Now my friend Kate, who lives up the hill has a 1200 gallon tank that is filled from her gutters after going thru a series of screens and filters. But Warren uses a 12volt pump that runs off the solar panels hooked into the old dug well to pump water periodically uphill to fill the tank. He's just 1 person living there but he's never run out of water.
In the pic you can see the tank uphill, the old dug well with the hand pump on it and then the pump is in the ground to the left below the sqare of styrofoam insulation you can see there.
Finally you can tell when somebody owns a gas well. Check out the outside lighting and inside the house is lighted by gas lights. Used to be he used Kerosene and heated with wood, and run his fridge on propane.
The brewers gather to party:thumbup:
