Check out the Bucklites. They're one of the best bangs for the Buck around (sorry, that just slipped out...): light, ultra tough, affordable.
how about emersons, such as the micro commander, mini 7 or mini a-100?
all are about 3 inch blade, with 1/4 inch pivots.
blade thickness is 1/8 inch, with thick tips.
ive been carrying a mini a-100, and im happy with it.
compact size, useful blade shape. its not the best slicer, but it gets the job done.
I sharpened a Kershaw #1830 Oso Sweet folder for a friend. It has a 3" blade with a pretty thick tip and seemed like a good budget knife, under $30 new online. It is a manual flipper with decent Chinese steel. Spyderco knives tend to have more distal taper, meaning thinner at the tip than many other knives.
Try the boker trance. Its 2.75in blade (AUS8), thin knife, but with a pretty tough tip. I'm not sure on the width of the blade, but I seem to remember hearing it was 1/10", which is in your range and it should hold up just fine to most things.
I think it would fit most of your needs pretty well.
You also might look at the spyderco Persistence, its also a 2.75in blade that is 1/8" thick.
Thanks! much appreciated.
For $55 you could get a buck vantage pro. Slightly over 3". Not sure how thick the blade is but it is thicker than most in its size. Bos treated S30v steel, g10 handles and a rock solid liner lock. Mine has no blade play at all and believe me, I check hard.
Get a Grayman Dua. Above your budget but you ll never have to buy another knife again!!
