I have a Smithy Supershop model 720 for sale or trade. It has all of the peices along with the accessories(router bits, drill bits, Forstner bits, saw blades, sanding discs, etc.). It is in almost new condition. I picked it up in a trade with a buddy that said he only used the table saw portion 3 times and that was it. I haven't used it at all. I'm looking to trade it for a nice KMG, Bader, Burrking or similar 2X72 belt grinder, or I will sell it for $2k obo. I've attached a picture of what it looks like, however I will post actual pictures of it up later today when I get home. It is a really nice unit, and I wish I could keep it, but I need another grinder!! Below is a cut and paste from the campbell tools website on it. Also, this is for pickup only due to the fact that its huge. I could possibly meet halfway within reason. You can email me at scmknives@yahoo.com .
Thanks, Steve
Get just the speed you need with 0-3600 rpm electronic variable speed. Changes are quick and easy with wrench-free, self-centering R-8 collet tool mounting system. Flip the machine to its vertical position effortlessly with the LiftAssist torsion spring. Maximize your depth of cut, SuperShop accepts 8, 10, or 12" saw blades. Get a lifetime of smooth service from the 3" diameter quill with 4 bearings. Move quickly and easily from one function to another with the rapid traverse rack and pinion movement.
Machine dimensions: 24" W x 72" L ..... Fits in the space of a workbench
Machine weight: 480 lbs. ..... Built stury for wobble free performance
Motor: 1.5 hp continuous duty ..... Actual, not "developed" power
Speed range: variable 0-3600 rpm ..... Can cut or turn wood or metal
Table saw: 10" carbide blade standard ..... Will accept 8"/10"/12" blades
Maximum depth of cut: 4" ..... Cuts bigger pieces in one pass
Ripping capacity: 48" ..... Cut a 4' x 8' sheet in half
Disc Sander: 12" diameter ..... Commercial size handles large and small jobs
Vertical mill: 21" high ..... Cut keyways and flats in large workpieces
Quill Travel: 5" ..... Longest travel in the industry
Table size: 17" x 21" ..... Tilting table for sawing compound cuts, drilling screw pockets or doweling quickly and easily
Lathe swing: 17" ..... Turn table legs or spindles for chairs and decks
Tool mounting system: R-8 collets 1/4 - 3/4" in diameter
Router/shaper makes fancy edges easy & accurate while stability enhances safety
The SuperShop stands 81" tall in the vertical operating position.
Thanks, Steve
