A snap temper is to slightly relieve any stress from the quench before cryo. It isn't a temper as-such. Once out of the cryo, the steel needs to be tempered.
All hardened blades need a temper cycle at around 400°F to convert the brittle martensite to tempered martensite. If the steel is a type that could have retained austenite, a second temper is needed. A second temper does no harm, so it is a good practice to always do double tempers, with a cooling to room temp between them. One hour is a minimum time for each temper, two hours being wise for higher alloy steels.
Tempering as soon after quench as possible is metallurgically wise. It doesn't have to be within minutes, but within a couple hours is smart. Once the first temper is done, you can delay the second temper for a day with no harm.
If your home oven won't hit 400°, you are in bad need of a new oven.
A toaster oven will work for a first temper while the HT oven is dropping to 400°F. Since toaster ovens can be a bit off in temp control, I would do a 375° temper in it, then wait until the HT oven reaches your temper point and do a second two hour temper.
You may have noticed that I used 400°F as the start of the tempering range. Tempering below this is done for a few blades that need near as-quenched hardness, but for the best toughness and edge life, tempering between 400°F and 500°F will yield the best blades.
People seem to think that tempering above 400° will drop the hardness greatly. In actuality, most knife steels will still be well above Rc60 with a 450° temper.
1095 tempered at 450° comes out at Rc62, which is what I recommend doing it at.
