Snare Wire ?
Guys, I am looking to add some snare wire to my PSK. This seems like a good item for a PSK in any climate due to the low weight and chance for food procurement with limited tracking skill. Looking for a good low-cost source for this item. It says on www.equiped.org to get SS wire vice brass. Where have you guys purchased this wire, and what gauge, length etc. works for you? Finally, has any one ever successfully snared game? stories and advice welcome. Thanks, DS.
you can get spools of thin ss wire at any hardware store it shoul dbe tought enough that it doesn't brake while being worker back and forth in the hands, I have a roll of such wire in my car kit but in my backpack kit I carry a full set of D'darrio #10 acoustic guitar strings (not nylon) the finer strings seem to be custommade for the job, I'm sure if you googled snare wire some interesting things would come up.
Thanks RR, #10 gauge guitar strings...great idea. I think I have some spare guitar stings lying around. I can always use and excuse to go to Guitar Center though....
darth,, look in Walmarts fabrics department or your local craft store and pick up a spool of floral wire. They usually have a few different gauges to choose from and it is cheap to. In my opinion you do not need to use stainless steel or other expensive wire because a snare is a one time use item. It is not like they will be out there in the elaments for more then a few days or so any way.
This page has pix of floral wire incase your not familiar with it.
http://www.ehow.com/how_6919_make-evergreen-garland.html
Good tips on alternate wire sources. All I have ever used was the brass colored stuff. I used to get it at hardware stores and fairly cheaply. Rabbits make little runways through the snow that are easily seen as they are fairly packed down. These trails are used often. Find a choke point between two trees or branches that a trail cuts through. Put your wire there. Its nothing fancy really. Just make a tiny loop, tist the wire, then loop the rest of the wire through the tiny loop you made. Now you have a slip knot, or noose type deal. Open up the noose, wire circle, whatever you want to call it to the size that you want. Aprox. 6-7 or so inches wide, whatever you are comfortable with. Thing is, if too wide it wont lock up around the rabbits neck. Anyway, make the choking loop, then snip off your excess wire, leaving enough to position the snare between the branches and tying it to one of the branches in a secure manner. If no tunnel between bushes, make one by chopping branches near you and force funneling the rabbit through your branches, on his regular trail path. You can corral rabbits a little. You can also get rabbits the hang around an area by chopping some newer bush then just tossing it were you want them to be. You will come back and find the snow trammped and rabbit wiz, crap evident. There really isnt much to this. You can set up a ton of snares in no time. Check them every day (morning)as Ravens or other predators will get at them. Snap off a visible branch by your trap or tie a piece of colored string in a bush above and close by the snare. Snaping a bush and pointing it down also adds the benefit of focusing that spot for feeding as the rabbits like the tender bush end chutes and buds. The brass colored snare wire is stiff enough that when you bend it into position, it will stay there by itself. Im sure there are more and better tips from others, but this has worked for me.
I use Hillman 24ga steel wire (.020). It comes in a 250 feet spool at either Home Depot or Lowe's for about 5 or 6 bucks. That gives you plenty to play with and plenty to pack away in various PSKs or BOBs.
I agree with Dirk.
I have the 22 ga. green steel wire from China Mart, cost 87 cents for 115 feet.
Yup, same here, got it at Lowe's, galvanized steel. excellent for snare wire.:thumbup:
IUKE12,
I didn't know it was galvanized. It doesn't say on the spool but when I got it, I was looking for stainless. It kindly looks like stainless but, whatever it is, it's pretty nice and thin... 24ga you can loop pretty good without kinking.
I also got a smaller spool of 22ga which I use for projects. It's a little thick for spooling up in my PSK. I may look at that green flower wire in WalMart next time I'm there, that green color may have some benefits.
Do you guys think the wires inside of phone wires will work. It think it is copper and has a coating.
Thanks
I think any wire will work as long as it can be bent in to shape and maintain it..I'm pretty sure you can make a snare out of justabout anything you can make a loop into. I'm sure somethings work better than others but the rabbit won't know the difference Les stroud snared a snowshoe hare w/ wires from a wrecked plain in one of his shows.
Growing up, my grandfather would only use braided picture-hanging wire. Very strong and extremely flexable and the braided strand tangled in the fur a bit. We snared big snowshoe hares and cottontails every winter.
J-
BrettP,, I have a feeling phone wire [and network wire] would be a little lightwieght for a snare. It does not take alot to break them.
-DD
Dirk,
Thanks for the input. My company has been doing a bunch of remodeling and i have found two types of wire so far. I am going to do some kind of test and see how strong it really is. I will keep you posted.
Good thread.
Ideally if you can get SS lock wire, that would be the best.
I am pretty sure that is was Doug uses in his kits. Very hard to find in small amounts though.
If you know anyone who works on airplanes, it is commonly used to lock the nuts on engines to keep them from vibrating off.
Someone somewhere once suggested trying SS fishing leader wire; I have not tried it yet, though.
Brome
I guess it depends on what you are trying to snare, but thin wire, besides the possibility of breaking, can amputate an animal's leg, leaving the animal crippled and you with only leg soup. Also, poorly made snares aren't very effective in keeping animals from escaping. Study some professional trapper's snares to see what I am talking about. Also check your local game laws. Some require locking or non-locking snares, and some require certain guage wires, and some require each snare to be permanently tagged with the owner's name and contact information. Some even require a special trapper's license. Posession of a device in habitat is lawful evidence that you are going to use it. Here, the animal cops have the right to search for such without a warrant. Yell and protest all you want, that is the tune.
Codger
What Codger said!
Don't forget even if snaring is legal where you are and you are licensed to trap, if it is out of season you can run a foul of the authorities by having snare making equipment on your person. Chris
