Here's the latest version from the spring up trap testing laboratories. The one in the picture is a true working model, but it is set up in my neighbour's yard. Occasionally we have a possum visiting, but I am not counting on catching one tonight.
The trigger mechanism is the one that Doc has been describing. I have made a bit of a variation by taking a couple of wraps of the top anchor loop around the trigger stick. This is not necessary, but it can help to make the trigger stick easier to find after the trap has fired. In this case it also provided a means of shortening the top loop to create a better angle for the stick.
As you can see, there is very little need to build a barrier to restrict entrance to the bait. There are two snare openings, and these cover the most likely points of entry. The tree that the anchor loops are tied to forms part of the back wall. On either side of the tree a stake has been hammered into the ground, and one stake is hammered in opposite the tree.
This forms a triangle...with the tree and two stakes forming the back wall or base, and the stick opposite becomes the apex of the triangle.
The anchor loops are made from strips of NZ flax leaf (Phormium tenax). The two snares and spring-up cord are black braided nylon. Each snare is supported by two thin willow pegs that have a split in the top for the cord to sit in.
A split bait stick loaded with bait paste has been lashed to the lower anchor loop.
With this set up, it is unlikely that the target animal will blunder into the trigger mechanism without entering the snare. I think that this model could be very successful. I will endeavor to set one or two of them next time I am setting a line.
