- Dec 27, 2010
Obviously still refining and so forth, and the handle and so forth is temporary, of course. This is my most ambitious sword project to date, and VERY challenging for an amateur like myself. As you can see, I listened to your feedback, since nobody seemed to like the straighter edges of my previous guard. This time I went for a simple curved guard. It's going to be pinned on, like normal bolsters, and I'm going to be using brass, because I'm dumb, and can't find any 3/8" steel for sale, and damascus is prohibitively expensive, and I would have to use mosaic pins to hold it on. I've also modified the pommel shape, and curvature of the handle to something more aesthetically pleasing to my eye.
This one is 36" OAL, with a 28.5" blade. It's made from CPM 3V. I ground this one down freehand without jigs, and as you can imagine, that was a challenge, as was grinding in fullers that long with my angle grinder. I've also never experimented with guards and bolsters before, so hopefully I got a good portion of mistakes out on this one before I put on the real ones. I got the balance point about 2" up from the guard by using 3/16" thick steel spacers, but that made the whole blade pretty ridiculously heavy. So I'm scrapping that, and will just use the brass guard to weight it, and hope that the balance works out okay so it will still be fast enough. I may also try to throw in some 1/8" liners so I can practice my file work some more, and get the balance to work a bit better.
As this blade is quite experimental, I'd appreciate any feedback you have thus far, recognizing that the fit and finish is still VERY rough, and I'll be using pinned construction for the scales and guard, with brass fittings and oregon maple burl for the scales. I'll be putting a convex edge on this after HT (which will be done by Peters, and I'm thinking 60 RC unless there's a good reason not to, since that's theoretically the ideal HT for 3V).
Specifically, where would you want the POB on a blade this long (think katana length, but obviously a wider blade), and how much would you sacrifice overall weight characteristics for an ideal POB? I ask because it's VERY heavy in the handle, and feels like a smallish bar bell in hand. Most of my actual dao swords are quite forward balanced, and it's becoming clear to me why. Thanks for looking!
