You'll find out faster by testing it than asking anybody
Seriously though, after quenching but before tempering, test the edge with a file, see if it skates. Make sure to test the tip of the edge, the middle, AND a spot near the ricasso. Gotta make sure you hardened the WHOLE thing.
Then after tempering, test it again. Do the brass rod test, and cut up a whole bunch of cardboard. If (after you sharpen it) the edge
flexes when you push it against a brass rod, but doesn't
chip but also doesn
deform... and you can cut up a ton of cardboard and still have it pretty much as sharp as when you started, then you're in good shape.
No need to tweak or make fine adjustements to your heat treating times and temperatures until you've got a process that basically works!
The only other thing is this: "Heated it red hot..." That's pretty vague. Did you check to see whether it still stuck to a magnet?
Reaching a non-magnetic state is a more reliable indicator that you got it hot enough than the color change. Not a perfect indicator, but better than eyeballing the colors.
Go ahead and test it, and YOU tell US whether it's hardened!
Good luck :thumbup:
Mike
