- Jan 3, 2014
I recently picked this 0450CF up on the forums and swapped the green standoffs out for some red ones from a co-worker's 0450, and I couldn't have been more pleased with the result.
Then I tried to sharpen the thing...
I also recently picked up the Blade Grinding Attachment for the Ken Onion Work Sharp. I'm pretty familiar with the WSKO and can get most knives very, very sharp, but the 0450CF just didn't wanna comply. Seemed like no matter what I did, it was just sooooo thick behind the edge, it wasn't really getting very sharp, just shiny.
After trying several times on the WSKO (starting at 120 and going all the way back thru the grits) I was still not getting the results I wanted, so I figured, I'll send it off to Josh or Big Chris or someone who can make this thing sharp again for me. But I figured, why not take one last stab at it on the Edge Pro Apex?
Since it's already pretty F'd, it's gonna be a user for sure, so I got crazy and took it down to 15 degrees on the EPA.
And it looks.... not great.
Even the non-knife dudes in my office are like "wtf...?"
It's still not as sharp as it should be, considering what I did to it. Was kinda hard taking it from convex back to a V grind, and it's razor sharp in the center, but the tip and the base are still not that sharp. I think I, if you can believe it, failed to remove enough steel (using diamond plates on the EPA) in those areas.
I just called it good cuz I was tired for the night.
Anyway, this is still likely headed out to someone for a regrind, but just thought I'd share my sharpening troubles.
