Codger_64
Moderator
- Oct 8, 2004
The Dagger Tupelo is just under 11', but it is a discontinued model. Check your local Craigslist. I've seen several canoes like it listed there recently for sub-$250. But I'd really advise against them if they are Tupelos or styled after them. It is fine for a kid, but way too tender for a full grown adult approaching 200#, never mind any gear. The 119K (or similar from the box stores) is wider, slightly longer (11'9") and much more stable on the water. And they weigh less than most loaded packs, about 45# depending on outfitting and hull materials. I did note on this brief trip that the Discovery 119K would have been easier to paddle with my kayak paddle (that I use in the Tupelo) than with the single blade canoe paddle. I hardly ever have to use the switch style paddling with my larger canoe, but course correction was pretty constant with the shorter boat, and not easily handled with a rudder-flip at the end of a single side power stroke.
Made between 1995-1998. Below taken from 1996 Catalogue. TUPELO SPECS: Small solo flatwater Royalite canoe. Length: 10' 6", center width: 27", shape: asymmetrical, weight: 29 lb., Depth 9.5". width @ 5" waterline 20.5", maximum capacity: 180 lb. (with 5" freeboard).
The Old Town Discovery 119K is a Superlink PE version of their Royalex Pack canoe. It was discontinued for a while but revived in 2009. Discovery 119 SPECS:
Length 11' 9", Width 32.5", Width at 4" Waterline 31", Bow Height 19", Depth 13.5", Weight 43 lbs / Max Load Range 450 - 500 lbs / Suggested Retail $600
Of course, the Royalex Pack is the cat's meow, being lighter (33#), but MSRP is $900. The price of the Disco can be cut a bit from $600 by getting the "Guide" badged one from the box sporting goods stores, $400 not on sale.
