- Oct 21, 2006
So, between making a lot of railroad spike letter openers to practice forging blade shapes, practicing grinding a bit for the last few weeks (destroying a few feet of mild steel in the process) I'd still never made a knife.
Using the new forge which got finished 2 weekends ago down at IGs and some 1084 which I got from David Schott last fall (Aldo Bruno's 1" x 1/4") I forged this blade to shape and rough ground it. It's quite obvious I need a lot more practice, because several hammer blows were deep enough that once I ground the scale all off and got the bevels to the right spots they were still visible. I also need a lot more grinding practice, because the plunge lines ended up not lining up exactly on the two sides, one is back about half a milimeter from the other.
I've got it at 60 grit right now, should i take it to 120 before heat treat? or is 60 ok?
It's ugly, but, baring any failures with heat treating, it should 'work'
