- Apr 22, 2006
The answer to this depends on what standards one has for "Premium".
For centuries the most common material for handles on knives and scales on folding blades was horn, bone or wood. Stag or horn grips became rare and expensive. Wood and bone are still available and widely used but can be a bit more expensive, can be heavy and can react poorly to moisture and chemicals. Leather has also been used. They can shrink with age or swell with water, etc.
Various plastics were tried in the post war period but these were generally less useful than wood or bone. But the experimentation led to the use of other materials some of which are widely used today.
Zytel is a fiberglass reinforced nylon. Less expensive than wood, bone or metal it is light weight, cheap to make, easy to work with, tough, and resists moisture. Many knife companies use it today. Exposure to some chemicals will over time cause it to fall apart (acetone, certain cutting oils, etc.).
Westinghouse Micarta has gained wide acceptance as a handle material. This began some decades back on knives. Impervious to chemicals, extremely tough, inexpensive, light weight and fairly easy to machine. It is available in a number of colors and can be polished or left rough. It is a high pressure laminate made of a composite of canvas or cotton cloth, fiberglass or carbon fiber which are layered together and baked under pressure. Very durable.
G-10 is a descendant of Micarta in that it is also a laminate baked under high pressure. It is a part of the FR-4 family of materials. It is made of woven fiberglass cloth and epoxy resins. It is easy to dye the material to achieve different colors. It is as tough as Micarta.
Carbon Fiber is more recent and is made of very thin strands of woven carbon fibers in a plastic resin. It is tough and very light weight.
These are all man made materials which are less expensive to make than aluminum, steel or titanium. They are not as tough as those metals. They are today the most common though.
Look around at pics of knives and note the different types of handle materials and how they are used. It is worth it to note the different textures and colors you can get with G-10 or Micarta. Both of which, on knives, are near indestructible.
I didn't mention resin impregnated wood which is also used today. But that's a different topic, maybe.
tipoc
Really great answer! I myself have wanted to see a breakdown like this for years. I have a basic understanding of each of these but not nearly as detailed. Thanks for the info. :thumbup:
