So what exactly is the " edge 2000" ?
The slipjoints were definitely different.
'86-'95 had the full flat, then '95-'99 I believe with the high hollow no swedge, and then '00+ for the hollow saber grind we still get today.
with the 300 series I personally think they were better before '00 , but there was a sweet spot back when the consistency and F&F on the blades was still really good.
My '03 305 is great, I still like my 80's-90's examples more but it's a toss up as to which are better.
There's something to be said for the 1st gen in house 300 series blades and for the 2nd gen blades which happen to not have a swedge.
The caveat is that my experience is mostly limited to the 305's which of course have pretty thin little blades, the differences in blade grinds is probably much more of a factor with a larger knife like the 301.
I agree with you 100% on the full flat grind slippie blades when Buck started making slipjoints in house. They are a different animal, cant have enough of them!
I remember back when the talk around the old local hardware store was that Buck knives were hard to sharpen. Some thought the metal was too hard and impossible to get a good edge. But that was because the edge Buck was putting on their blades was a convex grind at 25° per side instead of a flat grind at 15° and trying to sharpen on a flat stone it took a lol of wearing the convex grind to a flat grind to obtain an apex. I had learned this back in the 1980s and had figured it out by the time edge 2000 came along. Only i was setting a 17-20° angle per side at first then later going to 15° with a micro toothy edge . It sure made a difference in ease of sharpening and edge holding but also made it slice better. That’s when my coworkers were bringing me their knives to sharpen and reprofile and reset the edge angle.
When my 112 came in I put it on my Worksharp precision adjust to sharpen it and get the little knicks out.
I adjusted it to match what seemed to be the original edge, and that turned out to be about 17°-18° when I believe my 110LT was generally at 15°.
Does that mean this 112 was sent in for a SPA treatment at some point ?
I know the old edges were more obtuse and slightly convex, but what about the 90's 420HC blades ?
maybe just the various owners of it changed the bevel over years to their liking.....
Possibly, but it really doesn't look to have seen a lot of use and that bevel was very clean & consistent.
there's really no way to definitively say I guess.
belt sander....looks like factory...done them myself
A bit of Google searching has shown that visually there's really no obvious difference between a 90's 110 /112 and any post 2000 example with an even constant factory edge.
I think this is where my confusion came from, I thought the difference was supposed to be significant and very obvious.
A 1995 with an etch I borrowed a pic of so you know it wasn't used or sharpened.
And a 2005 I borrowed a pic of.
My guess is that your suspicions are correct.
Only way I can figure that edge would be on that knife is a spa treatment.
I was mistaken
It was only about a week ago but I didn't waste any time diving in and getting to work on this knife , I didn't exactly take a long hard stare at the edge.
Here is the before picture I took and it's pretty obvious now that this knife had definately seen some sharpening.
I matched my adjustment to the most shallow angle on the edge and reprofiled the whole thing to that which is about 18° on the sharpeners scale.
I would guess that what remained of the factory angle was around that 22°-24°.
Candidly, you would have to look very closely at the edge of two knives in order to see one sharpened to say, 50 degrees inclusive, and the other at 35 degrees inclusive. That's not going to be something you're going to notice immediately, other than the absolutely better cutting performance of the keener, less obtuse edge on the 35 degree edge.
I bought a used 110 two-dot a number of years ago at a pawn shop, the edge wasn’t just dull, it was flat! Decided to try the SPA, it came back beautifully finished with EDGE 2000 (didn’t think to mention keeping the original edge). I’m glad it is EDGE 2000 as it is the best cutting Folding Hunter I have used - great cutting edge with the retention of the 440C.
… I’m glad it is EDGE 2000 as it is the best cutting Folding Hunter I have used - great cutting edge with the retention of the 440C.
That’s one of the reasons I love the BCCI 35th 112 so much: 440C and the new edge geometry. You’ve convinced me to send this 2 dot in with the next batch heading off to Idaho for a pass across the grinder.
I'll bet that's an awesome knife.
I have nothing at all against nail nicks on knives that needs them and can live with 'em on knives that don't, but I really do appreciate it when a company leaves the nail nick on a knife that doesn't remotely need it.
I agree completely. And yes, it’s an awesome knife. It takes such a keen edge it’ll shave the hair off my arm without even unsnapping the sheath. LOL! I had it put away as a collector item for a while after I bought it, but finally broke down and made it a user/daily carry. And then I ordered another one and keep that one set aside. I was on the BCCI website yesterday and noticed they still have some left - which is shocking to me.
I'm just about convinced! I bought my two-dot 110 50 years ago and wouldn't change a thing about it, 'cause every scratch and scrape on it is a memory for me. But I have a two-dot 112 that I found a few years ago. The 440C gets plenty sharp, but I'd love to see how it performs with an Edge 2000, and the brass bolsters still have some tool marks that could be polished out. Yeah, I think I'm gonna do it!
Also -- I have a 1978-80 501 "Esquire" that I bought not too long ago. Again, the 440C gets plenty sharp, but wow is it NOT a slicer. For example, you really have to push on it just to slice an apple. 😁 I really don't want to change anything on it because despite its age it is in nearly NIB condition. But... I just found a nearly identical '78-80 501 that shows some wear, including a long history of sharpening. I bought it and had it in the mail the next day for a SPA and blade replacement. (Didn't even take time for "before" pictures. :confused:) Looking forward to seeing how I like the new 420HC Edge 2000 blade on it. (I know I'll like it.)
In my opinion, the Edge 2000 was a big step forward in cutting ability. I acquired several 110s in 2021 and all of them were significantly sharper and cut better when new than anything I got in the 1990s. No reprofiling is necessary. In fact, I think the Edge 2000 is about as thin as you should go with 420HC with Buck's heat treatment. I've experimented with thinning the edge a little on them and cuts like crazy . . . once or twice. I can go thinner with some steels/heat treatments that have better edge stability (like CPM154), but it's probably not worth the effort unless you really enjoy sharpening.
