What I've done on the few chef knives I've made with AEB-L so far, based on Chuck Bybee's (Alpha Knife Supply) recommendation, was to cut and profile before HT, then grind afterward. It's easier to keep the blades flat in HT if not beveled. At 62 Rockwell, the steel is surprisingly easy to grind. Of course you'll find it much easier to do with sharp belts, and I used 984F Cubitron II belts to rough grind with. The Fandelli ceramic belts that I have a few of, when about half used up, don't much want to cut hardened AEB-L. I also found that Gator belts cut hardened AEB-L quite well for scratch removal.
I'd recommend grinding it hardened for sure. I was starting with .090" thick stock, and it didn't take me too awful long to grind full height flat grinds on 8" chef blades 2" tall at the heel.
