Stromberg Knives
strombergknives.com
- Jan 3, 2015
Hi!
I received my Paragon oven a recently and after some reorganizing in my workshop everything is set up and ready for some heat treating.
I mainly use O1 tool steel and I have some question regarding heat treating of it.
Here's a snip from the instructions provided by my steel supplier:
Most O1 recipes will be similar of this, and they all speak of soak time after the steel has been fully heated through.
In this case it says 30 minutes per inch of ruling section. I interpret that as once the steel is fully heated through I should soak a 1/8 inch blade at 780/820 deg c for like 4 minutes? Would that be correct?
And how do I know that the steel i fully heated before I start the 4 minute timing?
If I understand correctly O1 doesn't hurt to soak for a longer time, but doesn't that increase decarburization and oxidation?
Wouldn't it be best to have as short soak time as necessary while still getting the austenitization done?
Thanks.
Hardening
Heat slowly and if possible pre-heat at 300/500 degrees centigrade before raising to the hardening temperature of 780/820 degrees centigrade.
Pre-heating is especially desirable for complex sections. Soak thoroughly, allowing 30 minutes per inch of ruling section before quenching.
Light sections should be quenched in oil from the lower end of the hardening range. Long slender sections should always be suspended in the
furnace for heating and quenched by plunging vertically into the oil bath. Tempering is always needed after hardening.
Thanks.
