1084 is a very basic steel, and is the eutectic. As a simple Fe-C mix there is no need to soak at austentitic temperature. Heat it to 1500F , hold it there only as long as necessary to assure even and complete heating, quench in fast oil. When you start adding alloy elements (including excess carbon) ,it becomes necessary to allow carbides and other compounds time to go into solution.
If you are using an oven, put the blade in at 1200F and ramp to 1500F. When it hits 1500F - quench.
Stacy
