**SOLD** AK 47 /74 K-VAR scope mount KV-04s for side rail QD
Feedback: +17 / =0 / -0
Arsenal KV-04S scope mount. Fits milled and stamped AK's that feature the side rail for mounting. Quick release lever. Used, Excellent condition. Did have scope mounted but never saw use in the field. Usually an out-of-stock item. Prompt shipment by Priority Mail.
$110
SOLD Paypal or Postal money order.
NO TRADES
For quickest response TEXT 720-560-1047
from KVAR:
Finally, a repeatable quick-release 1913-rail scope mount for your AK variant! The KV-04S features an adjustable locking mechanism that attaches securely to all military-standard AK side rails, and allows for easy removal and reattachment without tools or loss of zero. The 5.25-inch Picatinny rail section is centered over the bore axis, and can be reversed by the user for compatibility with hinged AK dust covers. The rail section and mount body are machined from aluminum alloy, with steel locking mechanism parts. Weighs just 7.7 ounces.
This is the must-have item if you are looking to mount a scope to your AK variant in the most accurate and solid way possible.
The KV-04S AK Scope mount provides a rigid platform with a Picatinny rail system (the standardized mounting platform for firearms). This KV-04S is virtually used for all scopes and optic devices with zero movement. Equipped with an adjustable quick-release lever mechanism allows you to remove and re-install your scope without losing zero. Now using Locktighting method on the rail so the screws are better secured. Fits on all standard military AK receiver side scope rails.
