Get em while they're hot!!!!!!
Just what the title says, budget lot including the following for x$70x NOW $60 --SPF TO DAN-- (shipped and paypaled). First person to say I'll take it followed up with a Pm wins it. Normal legal jargon applies, I reserve the right to sell to who I want to, etc.
All these are used but in working condition. Most have some form of modification done by me when I was in the tinkering mood. Each has a quirk, I'll try and explain each accordingly.
All have good fundamentals, some may need a little tlc (a cleaning or sharpening or pivot adjustment). All are solid beaters, if that makes sense? I don't have boxes for any of these except the Tenacious and the 1k.
- Spyderco Tenacious Blue. Wave opener put into the blade by me. Also stonewashed some of the shine off of the blade. Blade has some scratches. Centered with solid lockup. Have the box for this knife.
- Buck Slimline. Very lightly used. Has some lock rock, which was apparently common for these, but is fine otherwise.
- Ganzo 704. I put a wave opener on this knife and acid washed it. And dagum it, it looks good. Other than that it's a typical 704.
- Kershaw Swerve. This one was pretty significantly tinkered with, I did a swirl acid etch and then buffed most of it out so the etch is reasonably polished. I also cut a little more clearance out of the scale and liner where you push the lock down because these were hard to disengage as the came from the factory.
- Kabar Komodo. I used this specifically for free hand sharpening, and did a poor job of it. It has scratches and a sharpie mark on the blade. This knife flips open really smoothly and locks solid, probably due to the blade weight. It feels more solid than its normal retail price would suggest (if I'm not mistaken the scales are g10).
- Kershaw Emerson 1k. I didn't use this knife at all, but tried my damndest to adjust the pivot to no avail. The pivot spins and I couldn't figure out how to loosen it. That said it has some blade wiggle and marring on the pivot area.
- Gerber something or other.... Don't know much about this knife but it's pretty tint and locks up good.
- The Sog micron and the skull lanyard are freebies, just because I like you guys so much
Pics speak volumes:
Thanks for looking guys and gals.
Pics speak volumes:
