SOLD Benchmade Taggedout and Mini Grip
Feedback: +56 / =0 / -0
Benchmade Mini Grip - Hollow Grind - (154CM) - $125 SOLD (Paypal)
Older version of this Mini Grip. With the hole for flicking open and a really nice hollow grind on the 154cm steel.
This knife has been modified. I purchased it with a broken tip and then used a grind to blend in the broken tip. I then sanded that area to smooth it all out and did a nice acid wash on the entire blade. The scales have also been swapped to these dyed g10 scales. I also got some new bronze washers and teflon washers and decided to try a combination to see what the action would be like.
It is very, very smooth. One of the smoothest benchmades I've had. The teflon washers are against the blade side and then the thinner bronze washers are against the liner side. Perfectly centered and no blade play as well.
I have not used this knife at all after doing the work to get it to this point.
Will include a Benchmade blue box (Damaged) and original black scales.
Video & All Pictures: Benchmade Mini Grip
Benchmade Tagged Out - Full Size - (154CM) - $175 SOLD (Paypal)
Excellent knife that has been lightly used. I have done some customizations to this knife. Put on some aluminum scales from Applied Weapons Tech and did an acid wash to the blade.
Super smooth action. No blade play and perfectly centered.
Will include original box, original scales that have been dyed and extra deep carry pocket clip.
Video & All Pictures: Benchmade Taggedout
