**SOLD**Brous Carbon Fiber Reloader & Benchmade Limited Mini Onslaught
Bullet Beadz
Feedback: +128 / =0 / -0
Brous Blades Reloader Flipper Folder 3.5" D2 Satin Blade, Carbon Fiber Handles
Simply put, this knife is truly amazing!!
The guy that I bought it from described as such,
"An absolutely sick titanium liner carbon fiber scale Brous Blades Reloader.
This Mikkel Willumsen design is amazing, it locks in your hand like you would not believe, is comfortable, is a tank yet easy to carry,
it is truly an amazing knife. The blade is a work of art, as are the 3d scale which are anatomically notched.
The flipping action is out of the world, and it is perfectly centered with an amazing early lockup.
The pivot is just magic - the blade will fall shut on its own weight. "
The description is spot on and it's #91 of 250.
It is in immaculate condition with the only wear being on the spine where the Brous Blades logo is.
Comes with box, papers, sticker.
Asking $290 SOLD Paypal and ships USPS Priority fully insured with tracking to USA.
International shipping is extra and at buyer's risk.
See specs below:
Introducing The Reloader Flipper, A collaborative design between custom knifemakers Jason Brous and Mikkel Willumsen. The satin finished D2 steel blade features a unique main hollow grind with a flat ground tanto style tip and a thick secondary swedge on each side. The Reloader utilizes an integrated flipper for quick blade deployment on a ball bearing pivot system. The handle scales are made from carbon fiber with custom milled grooves for a secure and comfortable grip. The titanium liner lock is carbidized with tungsten carbide which provides a harder lock face surface and eliminates stickiness. The knife can be deployed either with the flipper tang or manually with the groove cut out in the blade. With stainless steel hardware and a reversible, deep set, tip up pocket makes this knife a great affordable every day carry blade.
Overall Length: 8.32"
Blade Length: 3.5"
Blade Thickness: 3/16"
Blade Material: D2
Handle Material: Carbon Fiber
Closed Length: 4.6"
Weight: 5.1 oz.
Finish: Satin
Made in USA
Benchmade Limited Mini Onslaught Axis Lock Knife 3.45" Satin Plain Edge
This came from the Shot Show in 2012 and was limited to 500 pieces, this being number 268.
Knife is used, but is in excellent condition all around with minor wear marks on the clip.
Smooth action and blade is centered with solid lockup.
Comes with box.
Asking $145 SOLD TO BEEMERMARK Paypal and ships USPS Priority fully insured with tracking to USA.
See specs below:
Bob Lum’s first AXIS Lock design embodies strength and smoothness and is now available in a limited edition version with carbon fiber scales.
The Benchmade Mini-Onslaught features the AXIS locking mechanism with modified clip-point blade.
Easy to open with ambidextrous thumb-hole opener. Satin D2 steel blade, plain edge.
Black carbon fiber handle scales with blue anodized aluminum barrel spacers. 500 piece limited run.
Overall Length: 7.78"
Blade Length: 3.45"
Cutting Edge: 3.125"
Blade Thickness: 0.114"
Blade Material: D2
Hardness: 58-61 RC
Blade Style: Modified Clip Point
Blade Grind: Flat
Blade Finish: Satin
Edge Type: Plain
Handle Length: 4.43"
Handle Thickness: 0.63"
Handle Color: Black
Weight: 3.90 oz.
Pocket Clip: Right Hand, Tip-Up
Knife Type: Manual
Opener: Thumb Hole
Lock Type: AXIS®
Brand: Benchmade
Model: 746BK-1201
Designer: Bob Lum
Country of Origin: USA
