sold-Early Spyderco Paramilitary C81GP
whitedog3322
Feedback: +110 / =0 / -0
Spyderco Paramilitary, black blade, serrated edge with a compression lock. From what I have been told this is the original paramilitary from 10 plus years ago. All that I can tell you for sure is that the blade is 3.0" long and the handle is 4.75" long. CPMSV30 steel which O do not believe was around back then so? If you are a collector it is used but solid as a rock. Blade is perfectly centered, lock up solid with no blade play in any direction. If you are a user it is very sharp still with WHAT APPEARS TO BE the original serrated edge. The black coating on the blade shows a lot of wear on one side and very little on the other side. The clips shows considerable wear but still works well. The compression lock works well but not as smoothly as when it was new. Asking for $sold or best offer. Comes with the original box, no papers.
It is yours if you want it but i have to come clean is has a 3.0" blade, not a 3.5". I just noticed what i had put down.
