For Sale Used/Like New Fenix PD35 TAC with factory sheath.
The Fenix PD35TAC features two general modes: Tactical Mode and Outdoor Mode. In the Outdoor Mode, the Fenix PD35 Tactical Edition delivers up to 6 output modes for maximum functionality. However, the Tactical Mode strengthens the PD35TAC with a simplified and faster operation. Perfect for outdoor use, professional use, security, & law enforcement, you can count on the PD35TAC to deliver reliable, powerful lighting for a wide range of situations.
Specifications
Thanks for looking.
Specifications
- Uses Cree XP-L(V5) LED with a lifespan of 50,000 hours
- New Cree XP-L LED provides up to 251% performance boost from XP-G2 LED
- Modes of Operation
- TACTICAL FLASHLIGHT MODE
- Turbo: 1000 Lumens (1 hr. 10 min.)
- Low: 60 Lumens (29 hr. 15 min.)
- Strobe: 1000 Lumens
- EDC FLASHLIGHT MODE
- High: 500 Lumens (2 hr. 55 min.)
- Mid: 200 Lumens (8 hr. 30 min.)
- Eco: 8 Lumens (140 hr.)
- Tactical tail switch with momentary-on function
- Rugged stainless steel side switch
- Side switch only capable of mode changing under Outdoor Mode
- Advanced digitally regulated output maintains constant brightness
- Low-voltage reminder indicates when battery replacement is needed
- Intelligent memory circuit, automatically enters last-used output mode when turned on
- Reverse polarity protection to protect from improper battery installation
- Anti-roll, slip-resistant body design
- Made of durable aircraft-grade aluminum
- Premium Type III hard-anodized anti-abrasive finish
- Toughened ultra-clear glass lens with anti-reflective coating
- Waterproof to IPX-8 standard, underwater up to 6 1/2 feet for 30 minutes
- Recommended Batteries: Fenix Lithium-ion Rechargeable 18650 batteries or two CR123A batteries
- Recommended Chargers: Fenix Battery Chargers
- *Batteries Not Included*
- 5.4 inches/137mm (Length) x 1 inch/25mm (Diameter)
- 3.1 oz./89-gram weight (excluding the battery)
Thanks for looking.
