SOLD Half Face Blades SHPOS Folder, BNIB
Nab762
Feedback: +71 / =0 / -0
Half Face Blades SHPOS Folder, brand new in the box.
Specs:
Sub Human Piece Of Shit monolithic folding blade, Gen 3. Blade geometry has been optimized as a fighting knife for slashing and cutting, not prying or digging.
8" overall open, 4 7/8ths" overall closed, 3" blade, 5/8ths" thick with pocket clip
Body - Machined solid billet 6AL-4V Titanium Type 2 anodizing. The body is a true monolithic frame which eliminates the need for backspacers, stand offs or additional hardware while gaining strength and rigidity.
Blade – S45VN stainless steel (58-59 RHC) with a proprietary heat treat to bond with a nitride coating (62 RHC).
Lock Up – Tapered button lock and bushing coated with nitride finish to wear evenly with the blade. System willll wear “in” with use, not wear “out”. The longer the blade is used, the tighter the lock up will get.
Pivot System – Dual, sealed roller bearings press fit into the frame. Pivot pin is captive to the blade and bearings eliminating all play in lock up and close. Dual bearing pivot system maximizes stability, while reducing friction in opening of blade.
Pocket Clip – Type 3 anodized aluminum pocket clip designed to be reversible on both sides of the body. Custom opposing inserts fill the gap to eliminate exposed threaded holes.
Push button blade lock release has a break in period Folders push buttons can be a little sticky new and takes time to break in.
Photos:
SOLD Shipped, paypal friends and family as payment. No trades.
