SOLD LensLight KO F
Feedback: +8 / =0 / -0
Need to sell this LensLight KO iN Tan. (Black mini not for sale)
Cover some costs For the coming Holiday.
2-Mode - $SOLD
Not much use. Carried once or or twice.
FULL DESCRIPTION
Output (Lumens): 400 or 9200 LUX (High) 5 (Low)
Length: 5.2 inches
Bezel Diameter: 1.06 inchesMaterial: 7075 Aluminum
Runtime: 2.2 hrs (High) 60 hrs (Low)
Batteries: 2x CR123 or RCR123 batteries
1) High Impact Hardened Optical Glass Lenses – protects the LED from the toughest of conditions and diligently bends the light much like a magnifying glass to ensure maximum brightness, distance, and efficiency. But don’t let the durability of a glass lens fool you, these lenses have been vigorously tested and designed to withstand excessive abuse while retaining optimal performance.
2) Patented Focusing Aspherical Lens System – This patented technology allows for a significant array of focusing options ranging from a flood to spot beam. This ensures that the perfect focus setting is available whether you are concentrating the light hundreds of yards away, or simply lighting up an object nearby.
3) 7075 Aluminum Aerospace Grade Alloy Construction– Defends against the harshest conditions imaginable and is shielded by a type III hard-anodized finish, a military grade coating available to resists corrosion and improve durability. (Available in either Dark Earth, or Black finish).
4) McClicky Momentary Activation On/Off Switch – This reliable easy to use tailcap switch enables the LensLight Mini’s 2-stage microprocessor to power the flashlight at either an efficient low setting or high output level for maximum brightness. Simply press down once for low setting, press again for high setting, or simply press all the way down for constant-on.
5) Light Emitting Diode –A premium exclusive high-tech, high-efficiency LED is used to emit astonishing power that is untouchable by any other light. This everlasting LED is sure to exert enough luminosity to stop any and everything in its track. Now that’s what you call an LED!
6) Premium Grade O-Rings- LensLight Mini contains 6 strategically placed O-rings throughout the flashlight to seal and protect the lights internals from dust, moisture, and any other micro-substance that it may come in contact with. This ensures that the LensLight performs at maximum efficiency at all times and your investment last a lifetime.
7) 2X CR123 Batteries – powered using two CR123 or RCR123 batteries.
8) Titanium Pocket Clip
(2) CR123 or RCR123 Batteries
Patented Focusable Aspheric Lens System
TypeIII hard anodize 7075 Aluminum
2-Stage Clicky Tail Cap Switch (low: 5 lumens/high: 400 lumens)
High Tolerance American CNC Machining
Double Lens - high impact hardened glass
Chem-Kote Contacts and Heat sink
Aerospace Grade Thermal Potting and Flow Management
Weather Proof/Water Resistant
Premium Bin High CRI CREE XPG-2 LED
Fully Regulated Light Engine
