- Apr 3, 2009
Hello,
Letting go of my Malkoff MDC neutral 1x123 sized flashlight. It has spent 99% of its life in my shop so not much carry and very little use. The Malkoff has a ss crenulated bezel installed. I'm also including 4 new Keeppower 800 mAh RCR123 cells and an additional unused Maratac AAA brass edc with the nichia 219C high CRI emitter. The maratac has a patina forming but is completely unused or carried. (Purchased as a backup to my aaa brass) Price for all is $OLD. No trades. (Basically getting the batteries and Maratac free) MDC specs listed below:
Malkoff MDC Head expressly designed for a single Li-ion rechargeable cell.* The output is 375 OTF Lumens.* It is a tailcap controlled multimode head.
This head will fit Malkoff MDC Bodies and SureFire E Series lights.* The head is constructed of 6061 T6 aluminum and Type III Hard Black Anodized.
The head has a Black Type III Hard Anodized finish. They are fully potted and use the same reflector as the M61 for a good balance of throw and spill.**The LED is a Neutral White (4000K) 95 CRI Luminous SST-20.
This head was designed for use with a single Li-ion protected rechargeable cell or two primary CR123A batteries.
Mode of Operation:
The switch debounce time is 150 milliseconds. The mode will advance each time the light is momentarily activated and the switch debounce time has passed.
This light*USES ON TIME*to determine mode switching.* If the light is left*ON*for more than 1 second, the*NEXT*off/on cycle will return the light to low.* If the light is NOT LEFT ON for 1+ seconds the*NEXT*off/on cycle will advance the mode.**The off time has no relation to the mode switching*of the light.* In most normal use, the light will always come on in low.
Summary of Modes:* 15 lumens/75 lumens/375 lumens
Current Draw:* 50 ma/270 ma/1450 ma
This upgrade was designed for rugged service from the ground up.* It is fully potted to stand up to rough service and recoil.* This item is covered by our Lifetime Warranty.
Mode of Operation:
