SOLD Maxpedition Malaga Gear Slinger in Foliage Green (as-new condition)
AmericanEDC
Platinum Member
Feedback: +22 / =0 / -0
$old TYD
It's effectively NEW but I don't want to lie and say it never had anything in it.
No staining, no abrasions. I used to store medical supplies inside the home, sort of a First Aid bug out bag (it has a ton of items organized inside). It never left my home for carry.
PayPal F&F please or Zelle I will ship to 50 states.
Ships UPS Ground Saver or USPS Ground Advantage.
In an effort to avoid misunderstandings: First “I’ll take it” in thread will likely take precedence but I reserve the right to sell to anyone for any reason; for example paid membership over free. Prompt payment is assumed following instructions - delays in hours would be grounds to move to next prospective buyer.
Malaga™ Gearslinger®
Ambidextrous Gearslinger loaded with great features and more.
Tough enough to join you on any outing or terrain, the Malaga is a traveler's dream. It's the largest ambidextrous Gearslinger with added features and both side and Y compression straps, so you can load it up and strap it down to increase your carry potential. There's plenty of take-along room for your laptop, ski jacket, emergency gear, blanket and supplies. Pockets and pouches accommodate your passport, airline tickets and personal items. GEARSLINGER® - AMBIDEXTROUS STRAPS
Gearslinger ambidextrous strap designs provide left and right side connections, allowing you to switch shoulders for convenient rifle shouldering, heavy carries and extended trips.
Specifications
  • Internal loop field for CCW
  • Inner organizer pocket
  • YKK zipper closure
  • Drainage grommet
  • Side and Y-compression straps
  • Adjustable cross strap for stability
  • Quick release access for easy on and off
  • Rear compartment can double as 50oz/1.5L reservoir
  • Overall size: 10.5"(L) x 6.5"(W) x 14"(H) View Product Dimensions Diagram
  • Main compartment: 10"(L) x 5"(W) x 13"(H)
  • Volume: 700 cu.in. / 11.5L
Materials
  • 1000-Denier water and abrasion resistant light-weight ballistic nylon fabric
  • Triple polyurethane coated for water resistance
  • High tensile strength nylon webbing
  • High tensile strength composite nylon thread (stronger than ordinary industry standard nylon thread)
  • #AS-100 high grade closed-cell foam padding material for superior shock protection
  • Internal seams taped and finished
  • Paracord zipper pulls
  • Stress points double stitched, Bartacked or "Box-and-X" stitched for added strength.
  • YKK® high strength zippers and zipper tracks
  • UTX-Duraflex® nylon buckles for low sound closures
  • Teflon® fabric protector for grime resistance and easy maintenance
Dimensions
Exterior front
  • Y-compression strap made from 1" webbing
  • One (1) 8.5"(L) x 2"(H) loop field for patches
  • Sleeve and paracord retainer
  • 3 rows of 5-channel PALS webbing
  • Four (4) 2.25"(L) x 1"(H) loop field points for patches
  • One (1) 9"(L) x 4"(H) x 1"(W) zippered pouch
  • Internal 3-channel elastic organization
  • One (1) 8.25"(L) x 3.5"(H) internal slip pocket
  • One (1) 8.5"(L) x 8"(H) external zippered pocket
  • One (1) 9"(L) x 9.25"(H) x 2"(W) zippered pouch with drainage grommet
  • One (1) 6"(L) x 4.5"(H) internal mesh pocket
  • One (1) 2.75"(L) x 4.5" (H) internal mesh pocket
  • One (1) 8"(L) x 6.5" (H) internal slip pocket
  • Keyper™
  • Internal 2-channel elastic organization
  • One (1) 8.5"(L) x 2.5"(H) internal zippered mesh pocket
Exterior rear
  • One (1) 9.25"(L) x 10"(H) padded compartment with 7.75"(L) x 7"(H) internal loop field for tuck-away strap concealment or CCW
  • Button-snap/Hook-&-Loop enclosure with D-Ring pull
  • Belt loop with Hook-&-Loop fastener
Exterior left
  • Side compression strap made from 1" webbing with 1" quick release buckle
  • 5 rows of 2-channel PALS webbing
  • D-Ring attachment point for optional ambidextrous shoulder carry or sternum strap
Exterior right
Exterior top
  • 1.25" padded grab handle
  • 4 channels of PALS webbing
  • 2 D-Ring attachment points for optional ambidextrous shoulder carry
Exterior bottom
  • Drainage grommet
Main interior front
  • One (1) 7.75"(L) x 8.75"(H) divider flap with rear Hook-&-Loop fastener
  • Two (2) 3.5"(L) x 5.25"(H) slip pockets
  • One (1) 7"(L) x 7.5"(H) zippered pocket
  • One (1) 10"(L) x 9.5"(H) slip pocket with 4"(L) x 7"(H) loop field for patches
Main interior rear
  • One (1) 11"(L) x 9.5"(H) slip pocket with Hook-&-Loop enclosure strap
  • Two paracord attachment loops
Straps
  • 3" ergonomic shoulder strap with 2" quick release buckle and attachment clip includes 5 channels of PALS webbing,1 elastic attachment point, 2 D-Rings and 1 slip pocket at base
  • Concealable sternum strap made from 0.75" webbing with distress whistle buckle
