I have a NIB Olight M20S Warrior Premium R5 Flashlight for sale.
I'm asking $65.00, including shipping and PayPal fees to CONUS.
I will only accept PayPal.
The light has been SOLD
First "I'll take it" posted here gets it. You PM after posting.
PICS
SPECS
The latest M20 Warrior Premium utilizes a Cree R5 emmiter, gives a max 320 lumen output and amazing throw. It is a perfect tactical flashlight as well as a EDC flashlight.
Specifications:
LED: Cree XP-G R5, life span up to 50000 hours, Max Output 320Lm
Weight: 120.5g without batteries
Dimensions: Overall length 140mm, Body Dia: 25mm, Bezel Dia: 33.5mm.
Functions: Three brightness levels plus strobe, 9lm (150hrs)-110lm (12hrs)- 320lm(4hrs), to select modes loosen then retighten head. Battery: Uses 2x CR123A 3.0v Lithium cells (Non Rechargeable) or Rechargeable Li-ion 3.7v cells either 2x RCR123A/16340, 1x 3.7v Li-ion18650 or 1x 17670.
Accessories included: Holster, Lanyard, Spare O-Rings, Spare fluorescent Tailcap Rubber Boot, CR123A Battery magazine.
Accessories Optional: Smooth Reflector, Remote Pressure Switch, Weapon Mount (Fits Picatinny/Weaver rail), Filters (Green, Red or Blue) & Beam Diffuser.
Features:
World-class super bright Cree XP-G R5 LED.
Three output levels and strobe, simple interface to adjust output, loosen head then retighten to select modes.
Automatic memory function, remember last used setting and can be preset to specific output mode for instant access.
Multiple battery choices, uses both Li-ion Rechargeable & Non-Rechargeable Lithium Batteries to provides the ultimate power to weight ratio and reliability.
Ultra Efficient Advanced Digital Power Management System for a smooth and even brightness over the duration of battery life.
Reverse polarity protection circuit to protect electronics against damage caused by battery being installed incorrectly.
Superior heat sink for quick dispersion of heat to protect LED and electronic components and ensure long life.
Tactical switch with momentary-on function, strike shroud and lock-out function to prevent accidental activation, protruding tailcap button for easy operation.
Superior heat sink quick dispersion of heat to protect LED and electrical components and ensure long life.
Ergonomic design, solid aluminium construction .
Tough durable Type III Hard Anodization
Built to meet Mil-spec: MIL-STD-810F.
O-Ring sealed to provide excellent water resistance and long service life.
Grip ring with anti-rolling design, enabling use with the different tactical holds, removable to convert to smoother straight body.
Stainless steel strike bezel (Removable).
Stainless steel pocket clip (Removable).
Ultra Clear Glass lens, non scratch with Anti-Reflective Coating.
Heavy duty quick release lanyard to prevent loss and easy access.
Interchangeable reflectors.
Full Textured (orange peel) Reflector provides a perfectly centred flawless beam reaching distances not seen in other LED lights.
Optional Smooth Reflector used to gain even greater distance for further targets, ideal when used as weapon light.
Battery magazine use with CR123A batteries, hold batteries firmly to provide excellent continuity and battery life under heavy shock or recoil.
More Info:
http://www.batteryjunction.com/premium-olight-m20-warrior.html
http://www.lightjunction.com/olight-flashlights/olight-m/premium-m20-R5.html
Thanks for looking.
PICS
SPECS
Specifications:
Features:
More Info:
Thanks for looking.
