Timestamp & Pics
NorthArm Skaha OD Green: (A)
The Skaha folding knife (Ska-ha) is a lightweight modern “flipper”
pocket knife. The blade is a highly useful 3.3 inches long and flips
very smoothly on miniature ball bearings. Pulling on the flipper tab
loads a detent to the point resistance is overcome and the blade
opens with a click using just one hand. Closing is also a one handed
operation in which the lockbar tab is pushed to the side to allow the
blade to close. As an every day carry (EDC) knife, the one handed
opening and closing makes it an amazingly useful tool compared to a
traditional pocket knife. The knife carries tip up via a single
position pocket clip.
We CNC mill the blade from CPM S35VN stainless steel. Our standard
“CNC” blade finish shows the milling contours that form the bevel.
We machine the handle scales from G10 epoxy-fiberglass layered
laminate, a relatively light but super strong material.
The bearings, pivot pin, thrust washers, stop pin and pocket clip are
made from hardened stainless steel. The lockbar is made from spring-
tempered S35VN.
I purchased this like new from the secondary market, which is about
the only way you can get them due to the huge backlog (they aren't
even taking new orders right now due to it). The knife is in
excellent condition and will be shipped in the plastic bag I received
it in. I am asking what I paid for it, $PF
Specs:
Maximum closed dimensions L x W x H: 4.4″ x 1.4″ x 0.75″ (11.2cm x
3.6cm x 1.9cm)
Blade length (tip to handle): 3.3″ (8.38cm)
Open length: 7.75″ (19.7cm)
Open length: 4.4″ (11.18cm)
Weight: 3.1 oz. (90 grams)
Blade steel: CPM S35VN
Blade hardness: HRC 59-61
Blade thickness at spine: 0.1″ (2.5mm)
Blade Grind: semi hollow (CNC milled)
Cutting edge angle (inclusive): 30°
Made in BC
tempered S35VN.
Specs:
3.6cm x 1.9cm)
Made in BC
- Note: I only ship to CONUS or Canada (Addtl shipping charges will apply and you are responsible for any customs issues after the knife leaves my hands. Due to new border restrictions, if you wish, I can disassemble the knife for shipping. Let me know.)
